How to change fog light bulbs on '04-'06 TL?
Everything under the engine bay is covered and the headlights dont appear to be accessible. I got new Nokya JDM yellow bulbs that I want to put in.
Any help...
Thanks!
Any help...
Thanks!
AZ Community Team
Received 7,770 Likes
Did you look here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Registered Member
Not at all necessary. Both fog lamps are accessible by hand, though the passenger side is tighter. Use thin rubber kitchen gloves and the job is not difficult. However, if you have large hands, it is not a walk in the park.
You have to take the battery out for the drivers side or at least i did the passengers side was no problem make sure you have your radio and navi codes also...Oh yeah there's also a small phillips screw that keeps the bulb in the socket that has to be loosened you don't have to take the screw completely out just loosen it and the bulb turns right out
I asked this in the other thread but is it possible to take the bulb out by reaching from under the car, behind the bumper to get to it. Without taking off the wheel well liner? I don't wanna mess around with the liner because my a-spec kit is nicely attached to the fender and loosening it up scares me because I don't think I can install it back the way it is now.
im gonna try installing the bulbs this weekend.. will report back how i make out. im not going through the wheel well though.. ill take off the panels/battery and install from there..
Registered Member
AZ Community Team
What I'm not sure about is if you can reach the fogs/HL from there. On an '07/'08, I know you could reach the fogs, but on the '04 - '06,
Registered Member
You can reach and remove/replace the fog lamps from the upper portion of the car without removing anything of consequence. It's a 10-15 minute job at best. You do not need to remove bumpers, wheels, inner wheel well liners, or batteries. All of this is completely unnecessary.
Undying Dreams (12-06-2012)
I'm doing the install right now. I got the connector removed but I'm not able to take out the bulb. The diagram says to turn it 45 degrees but no dice. Anything im missing? Any tabs or anything I need to press to remove it? So far it's a PITA
SirAwesometron (01-16-2014)
I was able to take them out shortly after posting this..
My first ricer
I just reached in and turned the bulb out, plugged in new bulb and turned back in. I already removed all the plastic panels so I don't recall if I had to remove anything else, but they pretty much pop right out.
sockr1
10-01-2015 01:31 AM
prox
5G TLX Problems & Fixes
09-01-2015 02:03 AM
