How to change fog light bulbs on '04-'06 TL?
Old Feb 15, 2011 | 05:21 PM
Project X's Avatar
Everything under the engine bay is covered and the headlights dont appear to be accessible. I got new Nokya JDM yellow bulbs that I want to put in.
Any help...
Thanks!
Old Feb 15, 2011 | 05:25 PM
Bearcat94's Avatar
AZ Community Team
Did you look here: https://acurazine.com/forums/3g-tl-2004-2008-93/3g-tl-garage-faq-3g-tl-newbies-553554/
Old Feb 15, 2011 | 10:24 PM
Project X's Avatar
What panels need to get removed to reach the headlights?
Old Feb 15, 2011 | 11:41 PM
greco9885's Avatar
take each wheel off, then take the fender lining out and bam its right there
Old Feb 16, 2011 | 06:46 AM
SouthernBoy's Avatar
Registered Member
Not at all necessary. Both fog lamps are accessible by hand, though the passenger side is tighter. Use thin rubber kitchen gloves and the job is not difficult. However, if you have large hands, it is not a walk in the park.
Old Feb 16, 2011 | 07:52 AM
booma1218's Avatar
You have to take the battery out for the drivers side or at least i did the passengers side was no problem make sure you have your radio and navi codes also...Oh yeah there's also a small phillips screw that keeps the bulb in the socket that has to be loosened you don't have to take the screw completely out just loosen it and the bulb turns right out
Old Feb 16, 2011 | 12:46 PM
greco9885's Avatar
may not be necessary, but i have access to a lift, air tools, and every kind of tool i can possibly need so i prefer to take things apart to make things easier instead of dicking around to try and get it done quicker, which usually doesnt work
Old Feb 16, 2011 | 02:45 PM
myron's Avatar
I asked this in the other thread but is it possible to take the bulb out by reaching from under the car, behind the bumper to get to it. Without taking off the wheel well liner? I don't wanna mess around with the liner because my a-spec kit is nicely attached to the fender and loosening it up scares me because I don't think I can install it back the way it is now.
Old Feb 16, 2011 | 02:48 PM
Project X's Avatar
im gonna try installing the bulbs this weekend.. will report back how i make out. im not going through the wheel well though.. ill take off the panels/battery and install from there..
Old Feb 16, 2011 | 03:30 PM
Registered Member
Why? I didn't need to do this and it was easy to do it from the front of the car leaning over the engine bay.
Old Feb 16, 2011 | 03:33 PM
Bearcat94's Avatar
AZ Community Team
Pretty sure there are a couple of under-body panels that you'll have to remove.
What I'm not sure about is if you can reach the fogs/HL from there. On an '07/'08, I know you could reach the fogs, but on the '04 - '06,
Old Feb 16, 2011 | 03:42 PM
Registered Member
You can reach and remove/replace the fog lamps from the upper portion of the car without removing anything of consequence. It's a 10-15 minute job at best. You do not need to remove bumpers, wheels, inner wheel well liners, or batteries. All of this is completely unnecessary.
Old Feb 16, 2011 | 03:55 PM
myron's Avatar
sorry I was asking about the HID bulb not the fog light/drl one. I forgot to specify, sorry.
Old Feb 20, 2011 | 11:58 AM
Project X's Avatar
I'm doing the install right now. I got the connector removed but I'm not able to take out the bulb. The diagram says to turn it 45 degrees but no dice. Anything im missing? Any tabs or anything I need to press to remove it? So far it's a PITA
Old Feb 20, 2011 | 02:46 PM
Project X's Avatar
I was able to take them out shortly after posting this..
Old Feb 20, 2011 | 03:08 PM
dgcdblockdgc's Avatar
Glad I came across this post. I wanted to change that bulb to a brighter white/blue color
Old Jan 16, 2014 | 12:38 PM
SirAwesometron's Avatar
Jordan Bierbaum
I tried reaching the lights from the hood.. I had a hell of a time with the drivers side one. Should I remove the battery?
Old Jan 16, 2014 | 01:08 PM
main70072's Avatar
It was a tight fit, but I didn't have to remove the battery. I just had to remove the top section of the tube that's in the way.
Old Jan 16, 2014 | 03:02 PM
350's Avatar
350
My first ricer
I just reached in and turned the bulb out, plugged in new bulb and turned back in. I already removed all the plastic panels so I don't recall if I had to remove anything else, but they pretty much pop right out.
Old Jan 16, 2014 | 05:45 PM
Stephen00TL's Avatar
Chapter Leader (Southeast Region)
I just did mine a few days a go you just have to remove the intake pieces on the driver side. It was a little tough to remove them but it was not to difficult.
Old Jan 17, 2014 | 12:37 AM
Cyanid3's Avatar
Been meaning to do this forever.
sockr1
Oct 1, 2015 01:31 AM
theinsvnity
Sep 10, 2015 10:22 PM
ellisd03tls
Sep 8, 2015 04:17 PM
cruisingnycfl
Sep 2, 2015 12:11 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
