Hit pothole
Old Nov 13, 2004 | 05:59 PM
6mtV6's Avatar
I6
Hit pothole
I hit a big pothole today on the highway. It made a loud "boom". It's the passenger front tire. I didn't blow the tire and didn't bent the rim, I think. Should I be worried? My TL drives normal. Sometimes when you hit a pothole your mind tricks you into thinking there's something wrong when there's not.
Old Nov 13, 2004 | 06:02 PM
Ron A's Avatar
Administrator
Considering the speeds that your TL can get to, and the temptation to use all that horsepower, your best bet is to go to a tire shop and have it checked. Probably they won't charge you, but even if you spend $10, it would be a good investment which could prevent an accident, injury, or loss of life.
Old Nov 13, 2004 | 06:05 PM
6mtV6's Avatar
I6
If I want to check it myself, what should I look for?
Old Nov 13, 2004 | 06:11 PM
Please look on the inside lip of the rim too, I hit a pot hole a few months ago and the outside lip of the rim was fine but the inside of the rim was dented and I replaced the rim. Better safe then sorry. Big pothole on the GCP.
Old Nov 13, 2004 | 06:14 PM
6mtV6's Avatar
I6
Is turning the wheel all the way to the left or right the best way to check the inside lip of the rim without taking the wheel off?
Should I be worried about the suspension also?
Old Nov 13, 2004 | 06:28 PM
yes I turned the wheel and kept moving the car up slowly to check and sure enough I found the dent on the inside lip. I took it to the dealer they checked the suspension the tire and the rim. They said the suspension was okay and the tire was okay, but said the rim had to be replaced. The dent was not that bad to me, but I didnt want to take a chance.
Old Nov 13, 2004 | 06:32 PM
6mtV6's Avatar
I6
How much does it take to check it at the dealer?
Old Nov 13, 2004 | 06:35 PM
They didnt charge me to check. They didnt force me to replace the rim either, but they did reccomend it. I hade to pay for the rim though. $283.00
6mtV6's Avatar
I6
Is pushing down on the fender right above the front tire a good way to check the suspension? Do I risk denting the fender?
Old Nov 13, 2004 | 06:39 PM
take it to the dealer is your best bet, pushing a fendor is not checking the suspension
Old Nov 14, 2004 | 12:11 AM
6mtV6's Avatar
I6
When you have a bent rim can you feel it when your driving?
Old Nov 14, 2004 | 10:47 AM
caha14's Avatar
A significant bend in a rim effectively results in an out-of-balance tire/wheel assembly out of balance. So you should feel it through the steering wheel at highway speed (shimmy), particularly since the tire you're concerned about is in front. If you have no shimmy, either the rim is fine, or the damage is minimal.
4drviper
Apr 23, 2025 07:13 PM
08KBP_VA
Oct 22, 2019 01:55 PM
ValdezQ26
Oct 1, 2015 04:48 PM
ceb
ILX
Sep 27, 2015 10:56 AM
