High mileage Oil
Old 01-23-2016, 11:49 PM
ericcdong's Avatar
High mileage Oil
Just wondering what type oil you guys run on your high mileage 3G TL's? Not sure what the previous owner of my car used but I've since have been using valvolines 5w30 high mileage oil. Is using high mileage oil even beneficial? I'm thinking of switching oils because a 5 L jug of this oil costs me about 45$ CAD. What do you guys think? My car is about 158k Miles on it.
Old 01-24-2016, 12:16 AM
b15
b15's Avatar
I use Pennzoil high mileage even though I only have 80k on my '06. These oils typically have extra detergents to help clean the engine and conditioners that theoretically should help worn seals from developing leaks. Whether that's true or not I don't know but it's only about $1 difference between the HM and regular Pennzoil here so I just use the HM. Also any reason why you're using 5w30 over the recommended 5w20?
Old 01-24-2016, 01:33 AM
Received 8,594 Likes on 6,638 Posts
Mobil 1 extended performance for me
Old 01-24-2016, 01:49 AM
DanV's06TL's Avatar
I used to use amsoil, but since I always change my oil every 5k miles, I've switched to Mobil 1. I can get 5qt jug at Walmart for about $27...
Old 01-24-2016, 02:08 AM
t-rd's Avatar
WHY? I've used the same Mobile1 5w-20 synthetic on my 07 Accord V6 for 220k miles. I have zero leak. Replaced front valve cover gasket, and some valve cover bolt grommets due to rubber hardening over time that's it. Cam and crank seals aren't leaking either.
Old 01-24-2016, 04:40 AM
YeuEmMaiMai's Avatar
100% agree no need to change oil on J series as the mileage racks up
Old 01-24-2016, 06:43 AM
nfnsquared's Avatar
Received 1,793 Likes on 1,346 Posts
OP, you should switch to Valvoline Broken Dong 5w30
Old 01-24-2016, 05:31 PM
No wonder you weren't able to pull on that Civic....
Old 01-25-2016, 10:05 AM
GKinColo08TL's Avatar
That Valvoline high mileage oil is a synthetic blend...use a full synthetic and you'll be fine.
Old 01-25-2016, 10:13 AM
wackjum's Avatar
High-mileage oil really works. But you should not automatically switch to it at some arbitrary mileage. You should wait until you have a problem and then try it out.
I have a bunch of older cars and switching to high-mileage does help slow or stop minor oil leaks and oil consumption.
Old 01-25-2016, 10:14 AM
nist7's Avatar
Received 1,094 Likes on 749 Posts
Yup same here.
Old 01-25-2016, 10:39 AM
WDPanda's Avatar
Mobil One full synthetic 5W-20
Used pennzoil and QS before but I saw a video on oils in sub zero temps and Mobil One sold me.
Old 01-25-2016, 06:26 PM
csmeance's Avatar
Received 1,989 Likes on 1,412 Posts
M1 Extended Performance Gold Cap. It lasts up to 15K miles, is full synthetic and is $28 at walmart for 5 quart jug.
High mileage oils tend to shear less, remain thicker during operation and have a few more additives like zinc, iron, etc to help keep bearings and such in good shape even after a bunch of miles.
GKinColo08TL (01-26-2016)
Old 01-26-2016, 02:03 PM
WhyteLegend's Avatar
OR
Old 01-26-2016, 08:54 PM
fsttyms1's Avatar
Received 3,063 Likes on 2,119 Posts
I was using m1 extended in my tl engine running 15 to 20k oil change intervals that had a little over 400k miles on it. Never used any oil.
Old 01-26-2016, 08:55 PM
fsttyms1's Avatar
Wish I could find the ultra platinum pure plus around here. Been running the platinum pure plus in my new 3.7 build
Old 01-26-2016, 09:55 PM
rapoM's Avatar
Best thing to do imho. Just keep running 5w20 Honda factory fill oil and keep the seals replaced. The seals usually start to fail at 120 to 140k miles. Including oil pump seals. Cam caps. Valve cover gaskets. VC grommets and tube seals can fail but not as likely. If you do your maint. On time.. like valve adjustment at 105k includes alot of gaskets... the rear main seals usually start to leak around 200k. And it's just a small seap.. anything can happen at any time.. but my judgements are based on the last 12 years of being a Honda master tech. Also. Secret here that should stay here. Honda factory fill uses Phillips Oil. Cheapest easy way to get this is to go to Walmart and buy Motorcraft oil. It's 95% the same. Or trop Artic. Or kendall. All the same oil. Made by Phillips. The kendall although sometimes hard to find comes in 3 performance levels. The first one is regular kendall. It's a semi synthetic (Honda factory fill IS semi synthetic) everything Phillips makes is semi or full. Anyway the next level of kendall is full syn. Then the 3rd and best is kendall full syn with liquid titanium. By the way. The base kendall out performes Mobil one in every way possible.. the tests are out there. I don't care to prove it. I've done my own uoa with Phillips oils.. good stuff. No to mention cheapest on the market (it's all in the marketing) ford and Honda and firestone.. maybe more use Phillips because it works the best. Not because they were offered it for a discount as long as they advertise for them. Aka mobil one on oil caps.. they don't need to pay for advertising. That's why the price is so low. Take the lowest grade Phillips semi syn oil. And put it up against BG. Royal purple. Red line. Pens crap. Anything. After you see its better. THEN you see its cheaper. then you realize you were paying for an advertisement.. Honda engineers aren't dumb. They use the best for their engines they spent millions building. Can't say the same for ford... think they just played follow the leader...
flwrngls (01-27-2016)
Old 01-26-2016, 11:04 PM
nfnsquared's Avatar
Why? There's nothing special about it's specs. They pretty much mirror M1 specs...
https://acurazine.com/forums/third-g...al-gas-907573/ . Post #4....
Old 01-27-2016, 07:01 AM
fsttyms1's Avatar
Why? Because i saw much better test/lab results with the old penz ultra plat vs the M1. There may not be anything special about its specs on paper, but it held up better for me in my long intervals. Im not saying M1 is inferior, just said i wish i could find the the new Ultra around here because i liked it better.
Old 01-27-2016, 08:03 AM
nfnsquared's Avatar
Old 02-05-2016, 12:42 PM
jblood37's Avatar
Could you post lab results? I'd like to see them if possible. Thanks!
Old 02-05-2016, 03:25 PM
nfnsquared's Avatar
x2...
The VOA on either the Ultra or the Ultra Platinum are pretty much exactly in line with the VOA on M1.
I'd love to see your UOA on the Ultra Platinum....
Old 02-11-2016, 11:10 PM
Mr. Detail
Scottwax's Avatar
208,000 and climbing on my '04 Accord, change the oil every 7500 miles with Penzoil Platinum 5W-20. Oil level never moves off the full line nor turns completely black so the motor is still pretty tight.
I had a couple of Maximas and the early VQ35s (and my first '02 was the 91st one made!) were known oil burners. Going to a heavier high mileage oil really didn't cut consumption much if at all. Best to stick with what is recommended in the owners manual.
Black Tire
12-18-2017 08:15 AM
VeNoMiZeD
04-29-2016 12:58 AM
jpeets82
01-28-2016 10:49 AM
deej0121
Integra
01-20-2016 10:29 PM
GK83
01-20-2016 07:02 PM
Quick Reply: High mileage Oil
