High Frequency Noise
Old Mar 22, 2005 | 09:45 AM
SI Guy's Avatar
Question High Frequency Noise
Is anyone else getting a steady high frequency noise when in Park and idling normally. It's not real loud and you can hear it only when standing Outside of the car...I checked the engine compartment which seems ok. Is this normal or is this the start of the famous tranny problems iv'e been hearing bout?
Old Mar 22, 2005 | 09:47 AM
cM3go's Avatar
are your headlights on? Could be your HID lamps... (which is normal)
Old Mar 22, 2005 | 10:41 AM
dsc888's Avatar
I do hear it but I think it's a normal noise from the exhaust. Get down near the rear and see if it gets louder. I think I know what you are referring to. I hear it on mine as well and never worried about it.
dsc888
Old Mar 22, 2005 | 10:44 AM
cM3go's Avatar
^ I forgot about that noise... If it is infact that noise that is normal as well
Old Mar 22, 2005 | 11:29 AM
SI Guy's Avatar
Thanks...will check out the exhaust...hey maybe I should fixate on the fumes..then the noise won't matter any more!
Old Mar 22, 2005 | 03:55 PM
Road Rage's Avatar
Not a Blowhole
A high frequency noise is likely not an exhaust note, as those resonances are low in the audible spectrum. Some people can hear high voltage ringing from coils, as in the injector solednoid windings, the high energy ignition, etc.
One thing always to check with noises is to see if it is RPM dependent - does the noise change as RPM varies? It is not likely to be the tranny, esp if we are talking about neutral here.
Old Mar 22, 2005 | 04:19 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
On some cars, the sound of the fuel pump is quite loud, but that tends to be near the fuel tank and not the engine. It would make sense, though, for the sound to carry in the fuel lines.
4drviper
Apr 23, 2025 07:13 PM
Fool
Mar 10, 2016 08:42 PM
RobbDizzle
Oct 15, 2015 11:16 AM
joflewbyu2
Oct 8, 2015 11:16 AM
rockyboy
Sep 29, 2015 12:05 AM
