HID KIT Installation
Hey guys,
I have a 2004 Acura TL, and im thinking about changing the headlights to 8000K. Instead of buying the whole kit can I just buy the 8000K bulb and use the stock ballast with it, will there be any problems?
Im thinking of doing the same thing with the fog lights..
Thanks for your help
Originally Posted by ribuchen
Hey guys,
http://www.shopxenon.com/ is just one of many out there.
9005 is the fog light number. I recomend staying around 6000-8000 Kelvin range for the best color and light outputs. 5000 will give you more output but will start to have a yellowish tint to it. If you want your fogs to work well in a bad weather situation you will need to go to a lower kelvin number like around 3000 to 5000. It will give you a yellow tint but you will be able to see through fog a lot better. If not then go with what i suggest. i doubt you would want to go to a purpleish look which is in the 10000 to 12000 ranges.
http://www.xenonpros.com is another one
cycdaniel
12-17-2019 10:58 AM
InFaMouSLink
10-27-2015 06:51 PM
nuldabz
09-03-2015 05:49 PM
