HID Foglights
#161
2K8 CBP TL-S 6MT
Originally Posted by gunner252
H11 BULBS WILL NOT FIT IN 2007 TL-S FOG LIGHT HOUSING. JUST WANT TO CONFIRM THIS INFO. lol
take you stock bulb and your HID bulb and put them next to each other
align them up as best as you can and use a dremel to reshape any of th 3 tabs of the HID to match the stock bulb and then you might get lucky
be very careful. and you might want to test fit it as you go
#162
Originally Posted by cKHyper
well some people for them it did fit...
Originally Posted by P.R.E.A.M.
if you feel like taking a change try this
#165
hmmmm well i got a H8 8000K kit from XenonDepot
they got some good reviews
#168
Question!
Hey, totally dig the 12000kelvin fog light bulbs. Here is a question for you if you don't mind answering.
I have an 2007 TL and want the same HID fog light bulbs on my car. Can you tell me the brand of HID's you have and if they were just plug and play bulbs or if I have to do more installation than that? I'm new to the whole working on my car thing but I really want the HID fog lights. Also, are those stock or after market headlight HIDs that you have?
Originally Posted by Porkipine
Hi guys, well I have a few questions and can't find the answer (unless its hidden somewhere).
Were you guys able to connect the ballast to the original lines?
The manual says the bulb is 12V-35W but doesn't ballast usually need an inital boost of 13V? Or is that not an issue.
Where did you guys hide the ballast?
What brand kit did you guys buy?
The stock HIDs are 4300k if I recall correctly. Does 4300k fog kit have a different color and intensity since the light is dispersed in the fog. Would a 5000k make the lights have similar look.
Thanks.
Thanks.
#170
lights don't look as bright in this one because I accidentally left the flash on
Hey can you tell me what type bulb you have for you HID fog lights? also can you name the kit? I have an 2007 TL and want to replace mine to HID's as well. Did you do it yourself? or take it to a shop?
#171
2K8 CBP TL-S 6MT
do it your self it's not that hard
#172
3000K kit like myself
Can you show me a link of where to get it? or where online you got it? Also, there has been alot of talk on the forum about H11 and H8 bulbs. Which one would I need for my stock TL? Thank you again so much for your help. I really do appreciate it.
#173
2K8 CBP TL-S 6MT
i will send you a PM about where I ordered them
#174
http://www.kbcarstuff.com/Xtreme_HID..._Kits_s/21.htm
i got the H11 bulbs & they fit in the OEM housing after about 60 seconds of sanding/filing on the housing (to get the tabs on the HID bulbs to fit in the holes). i did the install myself & it took about an hour & a half. my first HID install too.
#177
Originally Posted by 08 TLStockton
my bad its me again and i just seen someone say that the h11 dont fit foglights but the three tabs u gotta trim it with wire cutters or something it fits tho its h11
#179
plug and PRAY
Do the Plug and Play kits require a connection to the vehicle battery or is it just connected to the stock foglight plugs?
I was thinking of buying these?
http://cgi.ebay.com/ebaymotors/HID-X...mZ380007892121
I dont see any relays or connections to the battery needed in the photo...
#180
MY KBP IS BTR THN URS...
Ok Yes I Did Go Thru The Whole Thread.
1, Im Going To Get The Relay Cause Obviously Ill Need It.
2, My Question U Guys With The 07's Are U Still Able To Use The Factory Switch To Turn The Hids On And Off ?
#181
2K8 CBP TL-S 6MT
#183
2K8 CBP TL-S 6MT
Originally Posted by lopopo
Hey guys, im planning on changing my fogs to HID as well. Are there any DIY for 07 TL since the fogs are on the bottom and not in the headlights? Thanks
#184
all you need is a 8 or 10 MM socket(can't remember what size) and a flat head to pop the clips to get to the back of the housing but i removed my front bumper to make it a lot easier and clean to run the wires(i had mine wired with a relay)
#186
About Electrical Harness
Hi!! Hey guys, i've been wondering if i will have any problems installing HID's on my fog lights due to the standar electrical wiring on my 2002 Acura TL-S i have been researching about those relay's direct to the battery, My car has already installed (20amp) fuses for both OEM standard Fog's. in other words do i really have to worry about getting those relays or that only apply for the newer 2005's-to-up TLs???. thanks for your reply's
#188
Manchester United 4 life
I'd like to get the slim ballasts off of xenonspecs.com but I cannot find the relay harnesses on their site. Can anyone give me some feedback on where they got their relay harnesses online?
#189
More Than Meets The Eye
Ok, I'm probably one of the few people out there that do not care for yellow fogs. I want my fogs to match up with my stock HID's. (07 Type-S). Would it make more sense just to get a 4300K HID kit for my fogs?
Would it be a near perfect match?
#190
get the 6000k looks whiter and better imo i have that on my headlights and fogs.
#193
Hey guys does anyone do the yellow film thing? I was thinking about doing 6000k HIDs with yellow Film. But I am worried about the color, Should I do 4300k with yellow film. OR should I forget that plan and stick to the classic 3000k bulb. I kind of like the yellow film because it looks good when the lights aren't turned on. Any help is appreciated, I am short on time so please help!
#196
SlammedOnKonis
Anyone know the easiest way to take the diagram cover off? It's the metal cover that restricts the light output of the bulbs. It looks like it is held on by only a Philips screw, but I'm guessing the only way to remove that is to take the fog light housing apart...
Without that you can seriously blind oncoming drivers.
