HID bulb question
Old Dec 30, 2010 | 05:24 PM
Black Dameon TLS's Avatar
Question HID bulb question
Ok so I was doing some research and see that the 07' TLS main bulb size is the D2S. I just ordered a set of HID's and on the order it says D2S but I got a set of D2C bulbs. I called and they said it was the same thing.....is this true? Do i need to send these back?
Old Dec 30, 2010 | 06:01 PM
nate_0022's Avatar
Land of 10,000 lakes
You should be just fine. I believe it's just a different base design tofit other headlights such as the notches on the base of the bulb.
Old Dec 30, 2010 | 06:14 PM
Ok as long as they fit with no problems because it's to my understanding you have to remove the front bumper to change the headlight bulb....?
Old Dec 30, 2010 | 06:43 PM
nate_0022's Avatar
It's easiest to do it that way. Otherwise you can pull back the wheel well liner and try to do it that way but you need small hand to do that, especially that drivers side.
This is what a D2S bulb base looks like.
Old Dec 31, 2010 | 02:02 AM
chasemyTL's Avatar
Send them back. the D4C means colored this is not the route i would recommend at all. this is aftermarket companies trying to sell bulbs. Color temperature can vary.
Color temperature can drastically decrease light output. Not to mention alot of aftermarket products are made with poor quality control. The poor quality of the product cannot only affect the output it can also severely damage your headlight housing. the incorrect build of alot of aftermarket bulbs has also damaged headlight housings.
These damages are caused by heat. Poor design and lack of R&D of these bulbs give them improper placement (as in bulb rotated or mounting depth incorrect) Not to mention the Elements used to create reaction to produce light is something that must me monitored closely.
The reason heat damages the projectors. If you open up your headlights and take the projector assembly apart you will see that there is a chrome plated reflector bowl. the heat can cause this to fade, flake and dull the area. this can create dark spots/shadowing look to parts of your beam pattern. This is why you should stick to a quality product such as Osram, Philips, Hella ECT.
you need a D2S bulb. and make sure it is a D2S since you have a projector. take a visit to http://www.theretrofitsource.com/index.php?cPath=27. Matt is a very good reliable guy and will help with what you need i would highly recommend Phillips 85122+
Old Dec 31, 2010 | 12:44 PM
nate_0022's Avatar
He was reffering to a D2C, not a D4C. Here's a pic I found that should help you out.
Old Dec 31, 2010 | 01:32 PM
chasemyTL's Avatar
yea sorry i was a little tired when i wrote that. i meant D2C.
Old Jan 1, 2011 | 10:14 PM
According to your diagram above the D2C justlooks like it has an extra open groove on it VS the D2S. It looks as though the D2C would fit right? Like I said before, the company AAC said they were the same and wouldn't be a problem.
Old Jan 1, 2011 | 11:39 PM
nate_0022's Avatar
Just put them in and you'll be just fine.
Old Jan 2, 2011 | 12:51 PM
01tl4tl's Avatar
its fine--the bases interchange- make sure the bulb orientation is the same as the way the old one sat
Be sure the clip is in right and holds the bulb in place
Old Jan 3, 2011 | 11:57 AM
HIDStuff's Avatar
For simplicity, D2R is a reflector type bulb, which have a black stripe to reduce glare. D2S is for projector lenses. D2C don't have the stripe, so they'd work better in a D2S application.
Old Jan 3, 2011 | 04:25 PM
csmeance's Avatar
D2C bulbs are HID bulbs meant for housings without projectors. They have the back half of the bulb painted black to help stop glare. When you put them in a projector housing meant for D2S, they will fit, however their light output will be a bit less than your D2S bulbs even if they are the same color.
If you want new bulbs in factory color, the Philips 85122+ are the way to go! If you want 5000K, the OSRAM CBI's are the way to go!
Old Jan 4, 2011 | 06:35 PM
chasemyTL's Avatar
Not true D2C bulbs do not have any part of the Bulb Shielded. Only the the D2R. D2R The R stands for Reflector Optic Housings as seen on Older Escalades, IS300. D2S is meant for Projector Optics as found on the TL, S2000, ect.
oo7spy
Jun 19, 2023 12:48 AM
BoricuaTL
Apr 8, 2016 01:08 PM
truonghthe
Oct 1, 2015 03:13 AM
Silverstead1
Sep 17, 2015 06:45 AM
pesobreeze
1G RL (1996-2004)
Sep 3, 2015 12:26 PM
