Help with '07-'08 independent fog switch mod DIY
Subscribe
Apr 25, 2013 | 11:45 PM
so could someone please help a brotha out with this mod. I wanna retain use of the oem stock fog switch but also have the fogs on whenever I want. I understand that there is a DIY on this already but just one and it is mostly just informing that it's is possible but no one who has commented on that thread confirmed anything. what I need is a simplified DIY for this mod or even a modified version of this DIY for 07-08's (https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-07-08-acura-tl-diy-fog-light-mod-845798/) confirming wire colors and methods etc. thanks guys!!!!
Reply 0
Apr 25, 2013 | 11:49 PM
I'm interested in this too.
Reply 0
Apr 25, 2013 | 11:52 PM
Quote: I'm interested in this too.
greekguy000 and I wanna bang out this mod Saturday and hopefully will have something better to go by other than that other DIY. if all else fails in still gunna attempt it but if uve look at it in sure ull after that it's pretty confusing as well as just someone showing u how on a 04-06 with a few scans for our cars
Reply 0
Apr 26, 2013 | 12:23 AM
This is for the 07-08
https://acurazine.com/forums/3g-tl-2004-2008-93/110-b-diy-guide-replacing-3rd-4th-gear-pressure-switch-3g-tl-2007-2008-a-840630/
This is for the 04-06
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-independent-fog-lights-stock-switch-772633/
Very easy to do.
Reply 0
Apr 26, 2013 | 12:29 AM
The link for the 07-08 takes me to replacing the 3rd and 4th gear pressure switches?
Reply 0
Apr 26, 2013 | 12:31 AM
Quote: The link for the 07-08 takes me to replacing the 3rd and 4th gear pressure switches?
Sorry
Here
https://acurazine.com/forums/3g-tl-2004-2008-93/g-029-diy-07-08-3g-tl-independent-hid-fog-lights-stock-switch-798978/page3/#post13765029
Reply 1
Apr 26, 2013 | 05:32 AM
Quote: Sorry
Here
https://acurazine.com/forums/showthread.php?p=13765029
thanks but I want to do this without adding any relays or tapping into my hid kit. wanna use the DIY I have been looking at but it's pretty confusing
Reply 0
Apr 26, 2013 | 07:07 AM
I don't think anyone ever actually got anywhere with that DIY method you linked. Good luck though if you try it.
Reply 0
Apr 26, 2013 | 07:54 AM
if anyone has the hidextra.com fog kit ud know y I don't wanna go the other route. the relay is wired I the ballast in a way where I wouldn't wanna split the insulation. come on guys, anyone?
Reply 0
Apr 26, 2013 | 09:37 AM
This is the one I used but the pictures are down.
You will have to tap into a wire in your steering wheel column and I don't think I added a relay for this mod. If you want it to work and function and be trouble free, that is your only option.
Trust the ones who have done this, once you are done you will be glad you did this.
I have 2 relays by my battery. 1 for the Hid fogs and one for the LED DRL mod.
Reply 0
Apr 26, 2013 | 10:06 AM
I also have a relay with my led drl kit as well as two for my hid fog kit (each ballast has a relay attached I believe). anyway u could be more specific on how to go about this mod man, I really need help since I don't wanna fuck anything up as well as avoiding any errors in my dash
Reply 0
Apr 26, 2013 | 12:48 PM
nobody huh?
Reply 0
Apr 26, 2013 | 11:33 PM
gunna attempt this mod tomorrow anyway but was looking for some sort of confirmation that this method works and if not the steps needed in order to correct it
Reply 0
Apr 26, 2013 | 11:45 PM
Quote: gunna attempt this mod tomorrow anyway but was looking for some sort of confirmation that this method works and if not the steps needed in order to correct it
let me know how you make out, im also interested
Reply 0
Apr 27, 2013 | 12:15 AM
Good luck.
Reply 0
Apr 27, 2013 | 07:55 AM
If it were me, and I was concerned about f'in things up, I probably wouldn't have a hard deadline for when I was doing the mod. I would do it when I was more comfortable with exactly what needed to be modded . But that's just my
Reply 0
May 4, 2013 | 01:52 PM
still outta luck. come on guys, someone has had to do it using this method? https://acurazine.com/forums/showthread.php?t=772633
Reply 0
Subscribe
