Headlight needs replacement :( ?? advice needed!
Hi guys,
I had some trouble with my mobilus device (GPS tracking like viper) couple weeks ago. Now I realize that one of my headlight Xenon is not working anymore.
I thought the mobilus was plugged into the headlights in some way so maybe that would be the cause. I then asked honda to remove my mobilus as it wasnt used anymore.
Now the mobilus is removed and the headlights is still not work... I then checked all the fuses and there's nothing there!
I know it could get expensive if I need to change some Xenon parts. Could you guys let me know if I can do some more checks before surrender and bring the car to honda?
THANKS in advance!
THANKS in advance!
Land of 10,000 lakes
If it's just one side, what I would do I swap parts from your other side to try and diagnose the problem . Just make sure you swap one part at a time so you can figure out what the problem is. First off swap the bulbs, still nothing, move to the ballsts, still nothing then I think you have more than a headlight issue.
It actually isn't all that bad. The hard part is just taking off the bumper. Then just swap bulbs and see what happens. Then if that doesn't do that, the you'll have to take off the headlights to get the ballasts off. Shouldn't take more than an hour to do all of this.
the oem bulbs cost about 120 and the dealer charges 120 for labor...
buy after market bulbs that will be the same things as oem but 1/4 the price and change the bulb urself
take bumper off then have to remove headlights
its not as hard as it seems
i dont do anything myself on my car i pay for almost all installs except bulb changes cuz i went through 3 diff colors and finally stopped at 6000k
Soul_Deamon
11-13-2018 04:44 PM
Joseph Stansbury
34
12-04-2015 01:57 PM
