Headlamp Setup
Headlamp Setup
So I was looking at actually putting in HIDs into my Gixxer and at the same time I was going to order 12,000K D2S bulbs for my 05 TL and also change my fog lights to 12,000K HIDs. But I am reading that the TL uses 9005 bulbs for the high beams? Is this correct? I had thought the TL just moves something inside the lighting area to create the light to shine at a higher level. Am I wrong? Can someone explain to me how the high and low beams work on an 05 TL?
Thanks!
Thanks!
Im pretty sure what you are saying is wright.The low beam and the high beam are the same HID, something moves in the headlight so it will shine brighter or expose more of the bulb i should say. The bulb that is next to the HID closest to the grill is the fog light only not a high beam. In some cases it is a daytime running light. Hope that helps.
Well...depending on the year that could be right. On ours (04-05) the foglight is built into the headlight and it's a 9006 bulb. Our high beam is the bi xenon (hi and low) projector.
In the newer 07-08's...the foglight is in the bumper, but there is still a bulb in OUR fog location which I'm wondering, might be the high beams. Not sure if that means no more bixenon for the newer ones but it's possible that that's a 9005 now. Maybe?
The TL projectors are bi-xenon projectors, meaning they use both high an low beans in the same projector. When high beams are flipped on the shield drops for the high beam. Stay with OEM bulbs 4300k, you will have enough color from your color band from a distance.
Jul 16, 2017 07:33 AM
Sep 17, 2015 09:01 PM
