Head Lights
DDM TUNING Sells replacement bulbs for cheap! i've heard nothing but good things
about them and alot of members here have them on their rides just like i do.
http://www.ddmtuning.com/index.php?p...=264&parent=94
thats the link for the bulbs, just select D2S under bulb type.
For bulb color i would recommend 6000k, they are a good blue with good light output,
higher than 6000k will be more purple with less light output and lower with be more yellow/white
Hope this helps!
Hope this helps!
i have 8000k HID D2S and H11 HID for my lower fogs both from HID xtra...IMO HID xtra probably makes the best affordable HID bulbs for our cars...ive bought ones off ebay for the same price and they are garbage and some of them dont work or flicker
if you want to spend the money go with the 100 dollar kaixen bulb....if not 32 dollar bulbs from hid xtra are bangin
some have found a way thru the fender liner without removing bumper and light
Kaixen rock- our vendor excelerate has them or found online
5000k is as high as you can go and not lose a bunch of white light in front of the car- on the road to see with!!!
6000 you can still see with but not as well- dark roads are a problem except the lane lines light up brilliant!!
those pics are deceptive- you cant get a good image and bulbs change color and brightness with use- need 50 hours run time to burn in
cycdaniel
Dec 17, 2019 10:58 AM
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
Ny1718
Sep 11, 2015 09:21 AM
