Head Light Question
Head Light Question
Last evening I noticed a problem with my headlights. When I turn the head lights on, two indicators light up on the dash, both in the speedometer section of the console. One is blue and the other is green. I don't recall two indicators coming on before. Is this normal?
My problem is when I went to turn the fog lights on. No indicators went on in the dash, although I recall that an indictor would light up in tachometer section of the dash. Then I checked the lights when I parked the fog lights were not going on. Just to be sure, the fog lights are the inner set of lights, right?
Anyone else have a problem with their lights?
Mike
Mike
high beams
Looks like you have the high beams on because of the blue light you see in your dash, pull the headlight lever close to you, that will turn them off, and since you have the high beams on, the fog lights don't turn on. Once you have your low beams on, the fogs should go on fine and you'll see the light by your tach.
Originally Posted by campIIIMAF
didn't any oncoming traffic give you the signal that you were blinding them? second, is this your first vehicle?
What are you a F$%king comedian. If you read above, you see that I was running them in day time.
If you turn the head light on, the headlight indicator ON.
If turn foglight on, headlight & foglight indicaors ON.
If using highbeam, foglight OFF and headlight & highbeam indicators ON.
If you use highbeam, I'll beam you back whenever you're using it in daytime or night. So you should know what happens.
RLX-Sport Hybrid
3G RLX (2013+)
43
Dec 16, 2015 10:45 PM
wusty23jd
Sep 24, 2015 11:41 AM
Ny1718
Sep 11, 2015 09:21 AM
