HandsFreeLink?
Old May 12, 2004 | 06:24 AM
Ania's Avatar
Newbie
HandsFreeLink?
When i follow the directions in the manual it says that the remote has not been programed...how do i program the remote? Ania
Old May 12, 2004 | 08:49 AM
Ania's Avatar
Newbie
anyone?
Old May 12, 2004 | 08:53 AM
silverbishop's Avatar
What do you mean? Please try to enlight us on what you are trying to do. What phone do you use?
Old May 12, 2004 | 08:56 AM
Ania's Avatar
Newbie
ok maybe its not called that ... on the dash display where the odometer is there is something that you can program your lights to stay on...your doors to lock after so long..and so on and when i press the select button and hold it down it says that there is no remote programed.....but how could that be i open my door and stuff?
Old May 12, 2004 | 09:03 AM
Ania, you need to sync up your keyless remote with the car. I had the same problem before, check the manual to be sure, I believe you need to press the lock and unlock button at the same time to get the keyless remote to be recognized by your new TL.
Old May 12, 2004 | 09:14 AM
I concur with the above comment; just push the lock and unlock button on your remote (keyless entry is another accepted term) till you hear the beep sound. Then you can use MID to set your preferences...
Old May 12, 2004 | 12:40 PM
bzss7x's Avatar
Team Anth. Audio Engineer
Ania - I had the same problem. What I discovered was that I could sync the key fobs to the car by pushing lock and unlock at the same time but not putting the key in the steering column. I don't recall that part being in the manual. Good luck.
Old May 12, 2004 | 02:01 PM
Ania's Avatar
Newbie
It worked thanks guys
Tim Giron
Mar 18, 2016 09:50 PM
shotcaller88
17
Jun 8, 2006 06:29 PM
vp911
Jul 7, 2005 03:52 AM
gavriil
Dec 6, 2003 01:18 PM
