Got new pads on my Brembos
Brought in my 6MT for Service B and told them the brakes squeal a lot. Picked up today and found out they did 04-019 TSB and changed the pads and turned the rotors.
Also noticed the wear to be 7/32 on all tires (HPTs) with just 11,040 miles. Please share your experience with HPTs.
So, you got free pads and save $$$?
I thought the old 04-019 TSB was disabled weeks ago, and dealers are still waiting for the new updated 04-019 TSB.
Does this mean new one is there now?
Same story
I took my car in today for an oil change and I mention the brake squealing and gave the service rep the TSB number. When I picked up my car the service rep said that their district manager, who was visiting apparently, said that he had a memo saying that the procedure in the TSB did not work. However, they did replace my brake pads and re-surface the rotors for no charge. I will let you know if the squealing comes back. The service rep also said that Brembo is working on a replacement pad that is suppose to fix the squealing problem and that I will recieve a recall notice when the pads are available.
Hope this TSB will be carried over... you save $390... right?
http://www.acura-tl.com/forums/showthread.php?t=92573
Originally Posted by ColStripe
Man the rotor's turned at just 11k? That's not cool. Shouldn't need that for a good bit. You can only turn them so many times then you have to replace the rotor which will cost alot more $$$
Is refinished and turned the same? they wrote "refinished rotors" on the service order.
08_UA7_Gr33k
Feb 11, 2016 02:17 PM
LogicWavelength
3G TL Photograph Gallery
33
Nov 1, 2015 09:38 AM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
