My car pulls slightly to the right after new tires + an alignment. One thing the tech pointed out was the camber on the right which is at 1.8 but he didn't explain to me why he couldn't align it to proper specs, just that it was out of spec.
Its a 2008 Acura tl Base and everything is stock.
Can someone who knows how to read this tell me if everything looks right? Thanks
the road has a slight crown to it making the car want to go to the right most of the time. How much is it wanting to go to the right side? Like an entire lane within a short distance?
Is your steering wheel straight? Even with the specs being a little out, I don’t see anything that would cause a pull. Did you ask the shop again?
Sometimes as cars age, bushings, parts, etc things just don’t adjust like they used to. You would likely need new suspension parts to get it completely in spec but doesn’t seem worth it based on what I see on the sheet.
