Goodbye Tranny :(
So...here's the story. Battery was on its last leg so I went to go buy a new one. After taking the battery out I decided what the heck and checked all my fluids even though I had them checked out about a month prior. After checking my transmission dipstick I noticed that it was BONE DRY.
Decided to add a little in there to give it some lubrication, took it for a spin and things felt a whole lot smoother and thought I was in the clear. The next day I head off to work and I notice my MPG range wasn't at its usual threshold which is about 24-26 MPG. I was sitting somewhere in the mid tens. Didint think too much of it at the time since the trip computer was just reset. However, as time went on I noticed to lose more and more power and response time with the gears changing. Eventually, my tranny blew and my RPMs went straight up without any acceleration. I pull over and notice a trail of transmission fluid behind me...
I thought to myself...this mustve been one of the recalled TL's in 2004 for the transmission...luckily I had bought an extended warranty and just got the call back from them and they said that my transmission is COVERED!
Cant wait to get my bayyybeee back and driving again!
You knew about that recall but did not look into whether it had been done on your car? The very first thing I did when I bought my car was to make sure that all recalls and tsb's were up to date.
I'm glad it worked out for you, it would have been an expensive fix.
I blew the transmission on my mother's ody going up a hill on the freeway. We knew it was on its way out though.
also what fluid did OP use...?
so if he has a loose pan cause maybe he didnt tighten the bolts after changing the filter, or maybe the drain plugs werent properly secured or maybe he has a cracked pan gasket, or maybe even a rock struck and damaged the housing, that wouldnt be how it works? Well then, i'll defer to your examination of his tranny, and the explanation of what information we do have - namely the trail of tranny fluid.
No, that's not how it works.
How did you have extended warranty for so long? given that it is a 2004 TL...Is it possible to have extended warranty after 8 years? I have a 2004 TL too and my warranty expired in July of last year and I was told that I cannot extend any further..
Pham Alvan
May 18, 2021 06:48 AM
Pham Alvan
Mar 16, 2016 09:17 AM
lanechanger
Oct 13, 2015 10:56 AM
