Going on a road trip from MN to Yellowstone, WY Q's inside
FTW
My mid is showing 50% oil left, I have 59,000miles on the odometer, haven't done anything with my brakes or transmission fluid etc. My driving habits are spirited, but it's 70-80% HWY with 10mins of daily stop and go traffic in a 35-40min drive home.
General questions:
Total trip mileage is around 2,300 miles.
General questions:
- Should I change my oil?
- Check my brake pads, how many mm's should I be looking for?
- Should I tape my bumper area with painters tape to protect the front?
1. I always change oil before a major road trip, but that's personal preference.
2. ^^^ 3mm minimum on the pads.
3. Depends on what your bumper looks like now. If you already have a bunch of chips then don't worry about it. Even then you're *probably* safe. I usually see more rock chips in the spring when the roads are littered with sand and rocks.
Have a good trip, man! It's beautiful country out there.
I wouldnt worry about the oil if your still at 50 percent you should be good for 2k miles. Brake pads, take a look at them if they arent squeeling and dont look thin dont worry about them. Tape is a good idea as it definitely protects the front and I do it for long drives. If your at 59k have you changed your tranny fluid yet? I would recommend you change it before the trip
FTW
acura recommends changing the fluid at 60k which a lot of people say is way too much. most people change it sooner around 30k. you are at 59k so with 2k miles trip you will be over the 60k. If it were my car I would def do it before you head out. A full 3x3 change with redline d4 atf.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
