GM Synchro Mesh
Old Aug 24, 2012 | 10:00 PM
willy424's Avatar
GM Synchro Mesh
Just did a 1X3 drain and fill with gm syncho mesh fluid and couldnt be more happier. Got the stuff for about 10$ a quart at my local auto store
The car shifts like butter now, i love my car even more Thanks Azine
Old Aug 24, 2012 | 10:13 PM
truonghthe's Avatar
^^^I hope you know that 3x3 drain and fill is for AT right?
Old Aug 24, 2012 | 10:56 PM
willy424's Avatar
So i should only change it the next time i need a tranny drain and fill?
Old Aug 24, 2012 | 11:46 PM
VanyDotK's Avatar
Oh boy..
Do you have an automatic or manual transmission?
If you have an automatic you shouldn't be using GM fluid.
Old Aug 25, 2012 | 12:50 AM
TheChamp531's Avatar
Chapter Leader (San Antonio)
What.
Old Aug 25, 2012 | 12:52 AM
piggydog's Avatar
that gm stuff is only for the manual.
Old Aug 25, 2012 | 10:31 AM
anthracitecl's Avatar
Huh? GM fluid on AT?
Old Aug 25, 2012 | 11:57 AM
truonghthe's Avatar
OP ONLY AT require 3x3 refill with Redline racing ATF (Automatic Transmission Fluid) with light weight or other type (can't recall the name right now) or 3x3 drain and fill with Honda ATF D-1 (old ATF) and now is DW-1. I hope you didn't put GM fluid into your AT? GM fluid only recommend for MT to solve the issue with 3rd gear and there is no 3x3 drain and fill in the MT. I hope it clear thing out for you.
Old Aug 25, 2012 | 12:25 PM
What if GM Synchro is the cure for all A/T TLs and this guy just figured it all out! It all makes sense now!
Old Aug 25, 2012 | 12:43 PM
OTSB708's Avatar
uh...oh....
Old Aug 25, 2012 | 02:26 PM
07BLKTL's Avatar
In for the luls.
Old Aug 25, 2012 | 08:33 PM
truonghthe's Avatar
Originally Posted by thechamp531
what if gm synchro is the cure for all a/t tls and this guy just figured it all out! It all makes sense now!
lol.
Old Aug 25, 2012 | 09:41 PM
splew's Avatar
Originally Posted by 07BLKTL
In for the luls.
X2
Old Aug 28, 2012 | 09:48 PM
TrustinHFDJ's Avatar
Series Motor's
"DOH", Check out the user check in XD
quanaman
Jan 9, 2023 07:33 PM
Aug 15, 2019 12:58 PM
BoricuaTL
Apr 8, 2016 01:08 PM
scionxb3003
Sep 22, 2015 05:28 PM
DiamondJoeQuimby
Sep 10, 2015 11:40 AM
