Glove box rattle fix (hopefully)-PICT
Despite a quick fix of the glove box rattle by silicon spray, the cold weather has not been so kind to me. So, I took a good look at all the hinges that connect the glove box to the main plastic structure of the car. In my case, the right side of the hinge and the bolt (left side is shown in the picture below) was causing the rattle.
![](http://img.photobucket.com/albums/v355/twchun/untitled.jpg)
Even though the screw that attaches the black plastic piece to the frame was quite tight, I was able to simulate the same rattle by jiggling the glove box. It turns out there is a very small gap between the right behind the screw and the black piece of plastic. I took out a very thin layer of foam (less than 1/2"x1/2") and shoved it in the gap. It's been about 3 days since I've done this. I have not heard the glove box rattle at all.
I hope this helps those who have this annoying rattle.
Moderator Alumnus
Novice, that's exactly where my rattle came from... and I did the exactly the same treatment/actions as you have done. In my case, it held out for 3 months, then, it started to make noisy again. It rattled 'cause the screws wouldn't be able to tight it up anymore, and the gap was getting bigger after I opened it on/off a few times later.
Finally, I took a trip to my new dealer and they replaced all the screws insides and outsides, so far, I have no rattle from there...
(I still don't know what is difference btwn old/new screws.)
![Cross Fingers](https://acurazine.com/forums/images/smilies/xfingers.gif)
CEO, Team Anthracite
Moderator Alumnus
Originally Posted by Lore
Do you think if we replace the cabin air filter on our own it'll affect the screws that you speak of, or are they two different assemblies?
Kevin
Originally Posted by wyricke
Novice, do you still have this pic? The link doesn't work any longer. I have that rattle now, and it is driving me nuts.
Kevin
Kevin
I would like to see that too.
After my dealer adjusted my glovebox (becasue of a huge gap on the top part) my glovebox rattle all the time
![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
oyayjoe
09-12-2015 04:40 PM
3GTLOwns
09-09-2015 09:51 PM
