gauge brightness
Old Apr 20, 2004 | 09:00 AM
IIHII-TL's Avatar
gauge brightness
how bright does everyone keep thier gauges?
Old Apr 20, 2004 | 09:18 AM
cupidoneill's Avatar
TEAM NIGHTHAWK AP
low during nights and max during daytime
Old Apr 20, 2004 | 09:21 AM
marquis's Avatar
One notch down from max brightness (which looks the same as the max setting to me) so that the auto brightness on the nav keeps working.
Old Apr 20, 2004 | 09:24 AM
IIHII-TL's Avatar
so this will affect the brightness of the nav screen?
Old Apr 20, 2004 | 09:33 AM
marquis's Avatar
Yes....RTFM
Well, it depends. If you have your nav set to auto brightness, it will switch between day and night display based upon whether you have your headlights on or not....unless you have your gauges set to max brightness, in which case the NAV will always be on daytime brightness display. Again, RTFM.
Old Apr 20, 2004 | 09:38 AM
Seabee's Avatar
Team Anthracite Rocky Mnt
I drive with my headlights on during the day (I wish we had auto running lights like our friends to the North instead of the fog lights) So I hit the Max switch so I can see the dash, this also turns the NAVI on to “Day Mode” (assuming you have the NAVI set to auto). Then in the evening I hit the Max switch again and it returns to the dim mode that I have preset (Which is very low as I live in a rural area with no street lights) and the NAVI also goes to “Night Mode”.
Old Apr 20, 2004 | 09:46 AM
IIHII-TL's Avatar
dam it would be to much for me to always change the setting every night and every morning.
day time running lights would be nice. i have a habbit of tuning the headlights on as soon as i turn the key to start the car
Old Apr 20, 2004 | 10:12 AM
Tripp11's Avatar
Newbie for Life
Why not just leave the headlamps on?? You can set the time that you want for them to auto-off: 30/60/90 seconds I believe.
Old Apr 20, 2004 | 10:53 AM
caball88's Avatar
the brightest setting. i dun like the dull guage setting. it makes me kinda sleepy.
Old Apr 20, 2004 | 11:23 AM
porsche911's Avatar
Team SSM driver
Max during the day, one notch below max at night.
Old Apr 20, 2004 | 11:52 AM
WickedWiz's Avatar
Team Nghthwk Whipping Boy
Max at all times! keeps me awake at night!
Old Apr 20, 2004 | 05:12 PM
Ron A's Avatar
Administrator
Actually there is an auto off headlight setting, 0, 15, 30, and 60 seconds, so you could set it to go off when you shut the door after exiting the vehicle (assuming you removed the key from the ignition).
Old Apr 20, 2004 | 05:29 PM
abqhudson's Avatar
Happy in the Abyss
Only car I ever had
Only car I ever had that I have had to adjust the guage brightness between night and day.
Old Apr 20, 2004 | 05:33 PM
Tajam's Avatar
Team SSM
It changes automatically if you dont press max bright button, if you want it max during the day and change when headlights are on just use the arrows to set it on max and dont mess with it anymore..
Old Apr 20, 2004 | 06:47 PM
abqhudson's Avatar
Happy in the Abyss
Unfortunately.
Unfortunately, I like to drive with my headlights on when on the highway. In order to see the guages in the bright Southwest sun, that means max brightness in the daytime is a must. Then, it's too bright at night. So - turn it down is required at night.
Jul 16, 2017 07:33 AM
CL-S progression 01
Jan 26, 2016 04:15 PM
Sep 25, 2015 06:05 PM
eastcoastguy
Sep 23, 2015 06:29 AM
