G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
Old 12-18-2012, 10:07 AM
  #921
takin care of Business in
swoosh's Avatar
Received 4,732 Likes on 4,064 Posts
Originally Posted by EvilVirus
^ Thx I thought I read that you are running a .22ohm, correct and you dont get hyperflashing at all (with lights on or off?) So I guess I should remove my .33 ohm and get either 2 .12ohm or 1 .22ohm?
yes am running a 0.22ohm resistor....you will do just fine with 1x0.22 or 1x0.24
send a PM to BUDA....i know he had some resistors...
Old 12-18-2012, 11:13 AM
  #922
Cheval's Avatar
Ok took it apart again and my buddy who solders electronics for a living did the work for me this time. We tried the two 0.12ohm 1w 5% tolerence and solder them in series; results:
Lights off - everything works fine
Lights on - hyperflash
Decide to test a one .33 ohm 1w 5% tolerence results:
Same as above
I dont know if its because all of my interior lights are leds and my fogs are hids, and running LEDs in the front (switchbacks) and back (cheap ebay one) or whatever. I am going to keep researching around -_-
I have a 2008 TL and did this mod and have LEDs all around the car and also have HIDs for the fog lights and I have no hyper flashing. It all works great. One thing that I DID notice was I went to try out some different (v-leds I think) LEDs up front that I have and with those in there the lights hyperflashed so it seems like there may be some tolerances on what the flashing module(s) take and how it is affected by power draw on the line....
Old 12-19-2012, 04:36 PM
  #923
EvilVirus's Avatar
Received 1,120 Likes on 893 Posts
^ I am thinking it could be the front leds. i just got me some new ones and going to test those out this weekend before i go back to resoldering
Old 12-19-2012, 06:48 PM
  #924
Chapter Leader (Houston)
TLDude876's Avatar
Received 1,085 Likes on 810 Posts
Need you to help me solder mine
Old 12-19-2012, 07:53 PM
  #925
Project 04TL's Avatar
buda is out of them .. i just bought 10 from digikey. i dont mind sending some out but it will be after the first of the year
Old 12-19-2012, 11:19 PM
  #926
MEKO's Avatar
Received 2,321 Likes on 1,600 Posts
Just did mine
.24 from digikey
Thanks..
Old 12-20-2012, 09:21 AM
  #927
EvilVirus's Avatar
Lol sure let me get some practice in on mine first
Im in houston too but i dont think i have seen you around
Old 12-20-2012, 10:23 AM
  #928
i am usually in the bear creek area, i have only had the car for 6 weeks or so i can solder this for the local guys if needed
Old 12-20-2012, 08:38 PM
  #929
EvilVirus's Avatar
^cool dude welcome hope to see you in our future meets and yeah the help is welcome. do youhave any hyperflash?
Old 12-22-2012, 12:20 AM
  #930
i was testing the switchbacks i bought and had the hyper flash, not putting them in until i get the headlights. i havent done the mod yet, its on my list after i get back in town late next week. i just bought 10 resistors from digikey, let me know if anyone local needs them .. whatever is left i will mail out to other members on here.
Old 12-22-2012, 09:48 AM
  #931
rockstar143's Avatar
Received 19,991 Likes on 14,500 Posts
Well Cum to the forums, man...sounds like you're a cool and helpful dude. That's always appreciated here.
J.
Old 12-22-2012, 01:41 PM
  #932
EvilVirus's Avatar
Ok this is weird but my hyperflash stop. I wonder though if it was because i switch the rear leds for some brighter ones. After i did that i notice the next day with lights on or off the work normally and i havent resolder the relay yet. I will see how long this last.
Old 12-31-2012, 11:27 AM
  #933
TLDude876's Avatar
Another weird experience here. Did this yesterday and it worked fine after testing. About an hour later while driving, I hit the the turn signal and it only blinks once then stops. It is the same for either side and also the emergency blinkers, one flash then nothing. Any ideas?
Old 12-31-2012, 11:29 AM
  #934
swoosh's Avatar
loose connection....either you didnt solder well or the module is not in right....
are you using a 0.24ohm or a 0.22ohm?
Old 12-31-2012, 11:30 AM
  #935
TLDude876's Avatar
I used a .12 ohm. Only have LED's in rear.
Old 12-31-2012, 01:01 PM
  #936
EvilVirus's Avatar
swoosh does it matter what type of solder one uses?
Old 01-01-2013, 01:01 PM
  #937
swoosh's Avatar
Dennis then am thinking it is a loose connection....
nope, doesnt matter....but do use flux
Old 01-01-2013, 03:11 PM
  #938
TLDude876's Avatar
I just took it and flexed the resistor and put it back in and it seems to work. I'll continue to monitor it. I did manage to crack the housing for the relay
Old 01-01-2013, 03:14 PM
  #939
swoosh's Avatar
^^^ dont think you soldered it all the way....put a little more solder to hold it in place, and USE FLUX this time !!!
Old 01-01-2013, 03:45 PM
  #940
TLDude876's Avatar
I didn't, EvilVirus did
Old 01-01-2013, 06:46 PM
  #941
Engineer in Training
LockDots's Avatar
It absolutely does matter if you care about longevity. Use Rosin care, not Acid Core. Acid core will eat away at the joint/PCB over time. Most Rosin core solder already has flux inside it.
swoosh (01-01-2013)
Old 01-01-2013, 07:29 PM
  #942
EvilVirus's Avatar
^ ok tomorrow I will post the solder I used
Old 01-01-2013, 07:35 PM
  #943
swoosh's Avatar
^^^ didnt know that....thanks for the info
EDIT: @lockdots
LockDots (01-01-2013)
Old 01-01-2013, 07:41 PM
  #944
LockDots's Avatar
anytime
Old 01-01-2013, 07:46 PM
  #945
vietxquangstah's Avatar
http://www.radioshack.com/product/in....00+-+%2449.99
Old 01-01-2013, 08:17 PM
  #946
i finally got to this mod ... it took longer getting the relay out of the car than it did to actually mod it. i have 9 extras i can start mailing out tomorrow, shoot me a pm with your info if you need one.
Old 01-01-2013, 10:55 PM
  #947
AZP-TL's Avatar
FYI, I just did this mod using a .22 ohm resistor and it works perfectly with the new VLEDs V3 Tritons, which btw are insanely bright.
Old 01-01-2013, 11:17 PM
  #948
Can you post pictures?? I've been waiting for someone to post pics. Did you get switchbacks or amber or red for tail lights?
Old 01-02-2013, 12:10 AM
  #949
AZP-TL's Avatar
I got the switchbacks and the reds for the rear. I'll post pics tomorrow in this thread.
Old 01-02-2013, 08:15 AM
  #950
EvilVirus's Avatar
tldude keep me posted
Old 01-28-2013, 10:51 PM
  #951
Rickyp39's Avatar
hey fellas hopefully one of you can help me out. I plan on putting LED signals in the rear and REGULAR LED AMBER in the front (no switchbacks) Can someone tell me how many resistors and what size need to b installed and if there are separate relays for front and rear?
And if you guys could tell me where I could get some reliable bulbs from that aren't crazy expensive lol
Thank you!!
Old 01-29-2013, 10:41 AM
  #952
pm me your info and i will mail you a the resistor you need, i still have some extras
Old 01-29-2013, 12:02 PM
  #953
EvilVirus's Avatar
Thank you!!
If you read the 1st page it tells you what you need. I think page 3 has the pictures if you do them in series. Since you are putting in LEDS in the front and back then you need at least one .24ohm or two .12ohm solder in series. There is only one turn signal relay (which also affects your hazard fyi).
However, I had problems with the .12ohm series and the .22ohm and couldnt find a .24ohm (I'm such a noob to solder) but I dont know why though. Anyway, I went with a .33ohm and that works fine for me and a buddy I did it for too.
Old 01-29-2013, 07:04 PM
  #954
Thank you!!
www.vleds.com
Old 01-29-2013, 11:12 PM
  #955
Rickyp39's Avatar
Thanks for the help. I'm gonna try and get the .33 resistor and hope that works.
I had looked into the vleds and saw that the v3 tritons are $99! I'm all about spending the money for quality but are these things reliable? I ask cuz there is also a pair for $49
Old 01-29-2013, 11:42 PM
  #956
JJH
JJH's Avatar
They're a newer product and currently VLEDs flagship product. I haven't looked closely yet, but I'm sure they are covered with some kind of warranty. VLED wouldn't want bad word of mouth to get out about their flagship product so early in its product life cycle so I'm sure they had that in mind and build a durable product. I don't have them myself and don't plan on getting them.
PS - Does anyone have a .24ohm resistor that they could mail me? My switchbacks will be here before the end of the week
Old 01-30-2013, 06:50 AM
  #957
Project04 above looks like he said he has extras...
Guys, I wouldn't recommend straying from the ones that are proven and work. You won't want to solder and have to desolder this thing...the relay is a PITA to get out, too.
The following 2 users liked this post by rockstar143:
EvilVirus (01-30-2013), JJH (01-30-2013)
Old 01-30-2013, 10:12 AM
  #958
EvilVirus's Avatar
^ Hey mine works just fine though i am not stated everyone else should take my route. I agree if you can find the .24ohm then use that instead. I only went with the .33ohm because there was none avaliable at Fry's or any other local electronic places (which is weird to me) and I didnt feel like ordering online for just a damn resistor.
Its only a PITA for us M/T. You A/T were soooo easy to remove with no issues.
Time it took me to remove:
M/T = 20 minutes >:/
Friends A/T = 2 minutes
Old 01-30-2013, 11:12 AM
  #959
JJH, i will get one in the mail to you today.
Old 01-30-2013, 11:26 AM
  #960
JJH
JJH's Avatar
Wooohooo thanks!
Quick Reply: G-109: DIY-Eliminate LED Bulb Induced Hyper flashing WITHOUT LOAD RESISTORS
