Full Nose Mask - Vinyl
5th Gear
Has anyone installed the full vinyl nose mask? How was the fit, did it cause any problems with the finish, easy to install, happy with it, etc? I have seen some posts regarding the clear bra.....something to think about.
is learning to moonwalk i
I bought the full nose maskspecifically for a road trip. Installation wasn't what I would call easy, though it wasn't too bad. The toughest parts are getting the plastic 'pins/screws' out of the engine area and sliding the 'tabs' around the headlights. After the first install, it shouldn't take too long to put it back on. I leave mine off unless I'm planning a road trip, since I don't really care for the look.
I'm not sure if the dealer messed up the price, but I got the full mask for 160 +/- from Tustin Acura. Acura shows the cost at $300.
5th Gear
Thanks for the quick reply. I was looking to put this on for long road trips as well. I was also worried about damaging the paint from rubbing or something like that, but it sounds like that's not a problem if installed properly.
I haven't noticed any damage from the nose mask. As long as the car is clean when you put it on, you don't let it get too dirty while it is on and you keep the mask dry, it should be fine.
never stops!
The tabs which are to be inserted between the headlights & body simply won't go in all the way, they hit some sort of obstacle part way in, and are too flexible to be forced all the way in, they just keep bending.
Worse, the idiot who designed a rough-textured plastic tabs on the mask to be forced between the plastic bumper & metal fender on each side should be fired--not surprisingly a huge chip of paint was pulled off the plastic bumper on one side when I last installed/removed the thing.
I could easily envision that happening in other areas where you need to force fit tabs between headlights / body etc. VERY poorly designed.
100k miles club
i've only installed the half nose mask (hood) this morning. damn! that thing was hard to put on. debating on installing the bottom part until my road trip. is it harder or easier than the top piece? i got mine through ebay from acura of escondido for around $126 w/ tax and shipping.
i was planning to use it on a daily basis while commuting to work and taking it off while at work but after this morning's xp i may just use it on road trips
Mask
I have the full mask.
It's a pain to install until it gets stretched out and fits better. You need to leave it on the car, out in the sun, for a few days to loosen up. Since I run the freeway a lot commuting I leave it on for a week at a time and now it's easy to get on and off.
So far it has kept the front end of my TL from getting pock marked from road schrapnel.
Keeping the lining clean is a must to keep it from damaging the paint. So long as that's done it won't wreck the finish.
100k miles club
so i shouldn't have to worry about discoloration if i kept it on for a long time? and to keep the lining clean i'm guessing to use sponge and soap?
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
