Front and Rear Engine Mounts
Old 02-09-2019, 04:10 PM
SilvaTL06's Avatar
I need to replace my front and rear engine mounts but I'm not sure which brands are recommended? I see some aftermarket ones for a decent price but how does the car feel with non-OEM mounts? I've read some good stuff about Beck Arnley in general and I can get their front and rear mounts off amazon for $120 for both? Anyone have any luck using Beck Arnley? Also, the oem front mount is hydraulic and has the vacuum port. I'm not sure about the rear though? The Beck Anrley front mount is hydraulic with the port and rear is hydraulic but does not have a port? Is that fine? I dont feel like trying to plug the rear port if there is a rear vacuum line for the rear mount?
Old 02-09-2019, 04:20 PM
Slot Machine Lubricator
1black_seven's Avatar
Are you modding your car? If not just do OEM.
I wasnt under the impression our cars had a rear mounts other than the manual versions. I could be wrong.
Old 02-09-2019, 04:40 PM
SilvaTL06's Avatar
They definitely do have rear mounts but I'm just not sure if it has a vacuum port on it or not. I dont think it does but I'm not sure. And I ask about non-OEM because OEM front and rear mounts are close to $400 where as I could Beck Arnley for $120 for both and I've read good review about their mounts. I'm just looking to see if anyone has experience with their mounts too
Old 02-09-2019, 10:08 PM
SouthStar019's Avatar
both front and rear have vacuum port. I replaced all of mine with OE. including the Trans mount and trust me it was worth it. easier to replace all since the motor was out. i think you should be fine with the aftermarket as long as they have the vacuum port on them.
Old 02-12-2019, 06:21 AM
truonghthe's Avatar
Received 1,687 Likes on 1,303 Posts
I would stick with OEM mounts as the TL doesn't have the smoothest engine mount let say compare to RL in the same era, different manufacture will use different rubber compound thus causing more vibration even with the new mounts. Both front and rear mount has vacuum port.
I replaced all my mount with OEM and the car feels better but not as good as my RL lol.
Old 02-13-2019, 01:02 PM
Former Sponsor
MrHeeltoe's Avatar
We recommend going with factory OEM mounts if you are wanting to restore the Acura smoothness and quietness of the car. For performance we offer Innovative mounts and currently those are the only ones we really recommend for aftermarket.
You can save money going with cheaper aftermarket OE replacement mounts but odds are they will be failing sooner than the originals did.
You can hit us up for a discounted pricing on genuine mounts at OEM.Heeltoeauto.com
Old 02-22-2019, 04:04 PM
JMiles_T's Avatar
OEM mounts are the only ones I've found that won't make the vehicle shake like a cheap massage chair.
Old 02-22-2019, 04:05 PM
Received 8,611 Likes on 6,650 Posts
Surprised no one has mentioned OEM mounts yet
boxmanryan
01-12-2015 09:15 AM
MrHeeltoe
29
10-03-2014 07:17 PM
victus1
02-02-2012 11:43 AM
HQTL6SPD
08-08-2010 06:52 PM
ed'sTL
02-08-2009 12:47 PM
Quick Reply: Front and Rear Engine Mounts
