Friction modified fluid....
Old Jan 2, 2015 | 09:28 PM
devildon's Avatar
Whats up guys? does anyone know where in the San Diego area I might be able to pick up the syncromesh friction modified fluid to do a tranny flush? I would order it online but I dont have a mail box to get it sent to because the unit I am being stationed with on pendleton. Any suggestions?
Old Jan 2, 2015 | 09:37 PM
JTS97Z28's Avatar
You will just have to call around to any GM dealership and see if they stock it. If they don't they can possibly order it. Be advised though I have seen some dealerships mark this stuff up big time, so try not to overpay too much for it if you can avoid it.
Old Jan 3, 2015 | 02:39 PM
Adobeman's Avatar
The DVD-A Script Guy
Originally Posted by devildon
...to do a tranny flush?
Just want to make sure we are on the same page here. If you mean "simply drain and refill once" when you say "flush" then OK. Just want to make sure you aren't referring to the 3x flush/drain refill the AT owners do with ATF.
As JTS97Z28 said, since you can't mail order just call around to see what GM dealers have 3 quarts. I would not be surprised if they are looking for > $12/qt for it. Still worth every penny IMO for how good it made my MT.
Old Jan 3, 2015 | 03:17 PM
WDPanda's Avatar
2.2 liters / 2.3 quarts
Once drained, almost all the fluid comes out of the transmission.
I would bleed the clutch fluid (brake fluid) while you're at it.
Old Jan 3, 2015 | 09:28 PM
sockr1's Avatar
i live in SD and had a hard time finding it local. i'll subscribe to this thread to see if you find anything.
i ended up buying it online back in 2008 or so and bought a few batches but just recently ran out so i'll be getting more in the next year or so.
Old Jan 4, 2015 | 01:04 AM
Jesnutz's Avatar
I've purchased some in the past at a local dealer in Riverside but it was special order and they actually gave me a better deal. BTW I used this on my k20z3 trans
Old Jan 4, 2015 | 02:42 PM
Hi speed's Avatar
runnin a little boost
Summit racing sells this stuff for $11 per quart. You need to find some one in the SD area who also needs to do a flush and split 5 quarts with them, it will save you both. In the Bay Area dealers are charging $19 per quart. Summit ships same day and arrives next day with flat $10 shipping.
Old Jan 7, 2015 | 05:04 PM
millafied's Avatar
Just paid $12/qt on Amazon Prime last night. Its as low as $9 on there but probably not with free shipping and whatnot.
Was hoping to get a year out of the recent 60k service fluid change but I've changed my mind.
Chris
Old Jan 10, 2015 | 10:05 AM
devildon's Avatar
Thanks for the input guys, I did mean the drain and refill not the 3x3. Got it all figured out though had it shipped to someone's house that I was already at the unit. Amazon prime is the shit, took 2 days to get here.
Old Jan 10, 2015 | 10:33 AM
acrdr's Avatar
Why is noone putting the newest honda mtf in?
Old Jan 19, 2015 | 09:23 AM
DMZ's Avatar
DMZ
Head a da Family
True, Honda is claiming it'll fix the annoying 3rd gear issue, but after all these years, why not go with a proven fluid? If you put the new Honda stuff in and you're still having 3rd gear issues, then you have to do it all over again.
Paul, our mechanic in NJ claims the new Honda fluid and the GM/AC Delco fluid is now the same stuff and probably comes from the same manufacturer. I've been using the GM stuff exclusively for 10 years without a hitch.
Slow98teg
30
Jan 2, 2017 09:01 AM
Skirmich
Sep 19, 2015 04:16 PM
Sep 13, 2015 01:59 PM
JnC
Sep 11, 2015 06:06 AM
jfman55
Sep 5, 2015 02:55 PM
