Foglight Relocation
Old Jan 2, 2007 | 01:10 AM
  #81
foot3ch's Avatar
Raymond,
I finally did your foglight mods:
I'm going to take better pictures probably tomorrow. Check it out at my thread:
https://acurazine.com/forums/car-talk-5/top-10-stolen-cars-2003-a-141888/
Old Jan 2, 2007 | 02:03 AM
  #82
KB1Spec's Avatar
Nice.......good job....are those HIDs?
Old Jan 2, 2007 | 03:28 AM
  #83
mmcv6's Avatar
313.4WHP& 284.6TQ
both of your cars are nice with those accord fogs. I got one side installed now, and I will be putting on the drivers side wednesday if I got time... I was thinking about putting on HID in the fogs but I did not for now...
Old Jan 5, 2007 | 07:06 PM
  #84
SSM6MTNAVI's Avatar
Weather Watcher
Anyone installed these with the wiring harness provided. Just checked out a video that outlines this on the accord and I'm just wondering id its doable. I want to use the switch provided so I can run them independently. Wanna do it this weekend. Any insight would be great.........
Old Jan 5, 2007 | 08:01 PM
  #85
KB1Spec's Avatar
You can run both the stock and the aftermarket foglight at the same time. But for the aftermarket, you need to run a seperate wiring harness and switch to do that. So you can have both or one of the other. I didn't use the wiring harness that comes with the aftermarket foglight because I'm using the stock switch.
Good Luck
Old Jan 6, 2007 | 07:27 PM
  #86
KB1Spec's Avatar
For those who question about the installation of the puddle lamp and close up of the foglamp here is the pics.
Old Jan 10, 2007 | 12:09 AM
  #87
rockyfeller's Avatar
King of NYC
You did puddle lamps too? I was thinking of that but gave up on it. I see you did a recessed job. Looks great! How many do you have per sill? I was thinking of doing 4 or 5 per side. I see 2 broad types of puddle lamps out there; a 3 LED set which is more affordable and then there's a hi-end expensive really bright 5LED model. Which ones did you use?
Also by the way, how did you wire them? To a switch or directly tapped to other lights? I thought of somehow tapping these lamps to the interior/courtesy lights. This way they would also FADE with the rest of the lights.....How hott is that? They turn on when you unlock with the remote giving you light as you walk in and fade out with everything else! Wow this is tempting me more. How hard was the install?
Old Jan 10, 2007 | 01:23 AM
  #88
KB1Spec's Avatar
Yes I did the puddle lamp a while ago. I have 2 LED on each side. Because my friend (installer) told me not to waste money on it >_<. So he installed 2 on each side. I brought this one from this company www.varad.com or go here http://www.varad.com/productsl210.html
My friend wire it so when I arm or disarm the alarm it will goes on or off. Or when the door opens it will goes on. I believe my friend wire it up by tapping onto the interior lights. It is very install. The kit should comes with instruction to show you how.
Good Luck!
Old Jan 23, 2007 | 01:51 PM
  #89
datplayaz's Avatar
What kind of bulb does the fog light use?
Old Jan 29, 2007 | 11:57 PM
  #90
jpaik316's Avatar
06 RBP Acura TL A-Spec
i think you have the nicest TL on acurazine so far. very clean setup. not too crazy. Plus nice CBR in the garage. Cant wait till spring to start riding again.
Old Jan 30, 2007 | 01:12 AM
  #91
KB1Spec's Avatar
LOL my bike has been untouch for 6 months hee hee. Just start it up every other day :P
Old Jan 31, 2007 | 05:52 PM
  #92
grossman42x's Avatar
Spent
i would love to do this mod but unfortunatley i think i would muck it up big time. i wish there was another way.
Old Jan 31, 2007 | 06:07 PM
  #93
ILLustriousUA6's Avatar
Feenin on some 20's
wow man, u always amaze me with your DIY's....... keep it up man! i'm lovin the stuff u do.. keeps me outta boredom!
Old Jan 31, 2007 | 06:23 PM
  #94
KB1Spec's Avatar
ahahha thanks for the comments.....as always i try to venture new ideas....well...sort of >_<
Old Jan 31, 2007 | 06:27 PM
  #95
King of NYC
I see you have 2 lamps per side. What I meant to ask though is how many individual LEDs are in each unit. It looks like that Varad model is actually a single 1 Watt LED per unit. I was thinking of a 5 LED unit maybe. How's the Varad though? Is it bright enough. I assume you only really see it at night time right?
Old Jan 31, 2007 | 06:38 PM
  #96
KB1Spec's Avatar
Yes each unit have 1 LED. It is very bright during the night time. OR you can go with these
http://www.umnitza.com/product_info....oducts_id=1112
I'm in the process of adding 1 LED ight on to my side mirror shining downwards when I arm or disarm my car or when my doors are open. I think I'm overkilling it...am I? >_<
Old Feb 2, 2007 | 09:45 PM
  #97
terminex's Avatar
Terminex
Puddle lamps
I was actually thinking about getting those puddle lamps and installing them, but.....as my company just canceled ALL Bonuses for the year, it will have to wait.
Old Feb 2, 2007 | 09:50 PM
  #98
KB1Spec's Avatar
Ebay!
Old Mar 16, 2007 | 01:12 PM
  #99
KB1Spec's Avatar
Well after relocating the foglight on the bottom grill., I was pretty satisfy with the outcome. I know a lot of people here in the forum followed my step and happy what you all did to yours! Since the out put is somewhat mediocre, I wanted a sharp cut off from the beam. So my next project to cut open the foglight housing and install these Bosch Mini Projector:
Dimension of these are as follow:
Max Outer Diameter = 2 3/4"
Lens Diameter = 1 1/2"
Max depth = 3 3/4"
Since the projector is about 1.5 inch in diameter, I feel that it would fit easily inside the housing and also give a good flat cutoff. Just like to see what is your thoughts on these.
Old Mar 16, 2007 | 02:13 PM
  #100
SteveP66's Avatar
Kaa - Ching !!!
From: Rhode Island.....Self-Proclaimed Chromed Cousin of Brettallica
Would you still have the same pluf n play for the wiring or would that need to be swapped out?
Let us know how they turn out - some of us haven't done the Honda ones yet........this might be another alternative
Old Mar 16, 2007 | 02:28 PM
  #101
KB1Spec's Avatar
Same plug and play wiring. I have HID on the foglights so I am still using the same stock wirings. But only thing is that I will be using the same foglamp BUT I will cut it apart and put in these projects and then seal it back. So it will be the same foglamp but just that I stuck in a mini projector.
Old Mar 16, 2007 | 03:03 PM
  #102
THTL's Avatar
having projector for foglight is really nice, please keep us posted.
Old Mar 30, 2007 | 10:38 PM
  #103
warrior15r's Avatar
I'm planning to get mine installed soon. I was wondering, anyone know how to wire the fog lights so that they'll automatically turn every single time headlights turn on and retain the ability to turn the stock fogs on/off?
So in other words, every time my headlamps turn on..the accord fogs turn on...every time i turn headlamps offs, the accord fogs turn off as well.
Old Mar 31, 2007 | 02:15 AM
  #104
KB1Spec's Avatar
You can but need to do some wiring modifications. I'm not too sure how but there is a way to do that. YOu can do it where when you just have the parking light on...the foglight will be on as well. I believe you just tap one wire to the parking light wires.
good luck
Old Apr 2, 2007 | 08:12 AM
  #105
maddsiick's Avatar
Mistuh DRiiVA
Im goin to do this mod today and i wasnt really sure about the L bracket part of the DIY. Where exactly does it go? I have all the materials and have removed the bumper and grill inserts, i just dont know where i should put da L bracket to hold the lamp. Thanks ua6spec!
Old Apr 2, 2007 | 09:51 AM
  #106
Crook's Avatar
Post #46 in this thread has some tips to show you how to wire your fog lights to turn on when your parking lights or headlights are turned on.
Old Apr 2, 2007 | 09:43 PM
  #107
Blackthought95's Avatar
5th Gear
I noticed no one responded about the "airflow" comment, is this a major issue or not?
Old Apr 5, 2007 | 03:48 PM
  #108
maddsiick's Avatar
Mistuh DRiiVA
when wiring the fogs to the car, you can run it to the existing fogs to make use of the stock switch and still turn on the stock fog lights? Im doin the install tommorow and id just like to know how many wires im actually going to need and how to wire it using the existing stock switch. Thanks
Old Apr 5, 2007 | 04:04 PM
  #109
THTL's Avatar
can you please take some photos during the installation.
Old Apr 5, 2007 | 11:18 PM
  #110
BAO-7786's Avatar
check on my foglight
http://i155.photobucket.com/albums/s...t/DSCF0728.jpg
http://i155.photobucket.com/albums/s...t/DSCF0727.jpg
http://i155.photobucket.com/albums/s...t/DSCF0735.jpg
http://i155.photobucket.com/albums/s...t/DSCF0734.jpg
http://i155.photobucket.com/albums/s...t/DSCF0736.jpg
Old Apr 5, 2007 | 11:33 PM
  #111
THTL's Avatar
hey Bao did u do the install yourself
Old Apr 5, 2007 | 11:40 PM
  #112
BAO-7786's Avatar
the toplight i did.but the botom one i have pro do that.u must remove bumber to run the wire and locate the light.and it not cheap,
Old Apr 5, 2007 | 11:45 PM
  #113
THTL's Avatar
where and how much.
Old Apr 5, 2007 | 11:53 PM
  #114
BAO-7786's Avatar
i using 07 tl-s foglight, that y it cost me.for both light cost me around 500$.and 15000k HID 320$
Old Apr 5, 2007 | 11:55 PM
  #115
BAO-7786's Avatar
i had them done in wesminter,ca. USA tinwindow
Old Apr 6, 2007 | 12:36 AM
  #116
tracerit's Avatar
BAO where do you live in Westminster? That's a really nice house for that area, condo or house?
Old Apr 6, 2007 | 12:52 AM
  #117
BAO-7786's Avatar
it is a house. but we talking about car here.
Old Apr 6, 2007 | 08:29 AM
  #118
maddsiick's Avatar
Mistuh DRiiVA
wow BAO, those look great...i hope mine come out that good when im done with it
Old Apr 16, 2007 | 07:27 AM
  #119
maddsiick's Avatar
Mistuh DRiiVA
Does anyone want a pair of 03-05 accord foglamps for really really cheap with mtec h11 cosmo blue bulbs? i wanted to do this mod and bought all the pieces but i realized that it is to hard for me to do it myself. Think i got a little in over my head with this project lol. Anyone interested? Really cheap, i just want to get rid of these lamps. They work perfectly.
Old Apr 16, 2007 | 07:34 AM
  #120
SteveP66's Avatar
Kaa - Ching !!!
Did you start to do it Mad? The only part that itimidates me is the wiring but when the time comes I know the forum will guide me...........
