Foglight mod for the 07+?
B A N N E D
1 Post
Hey guys i was trying to see if theres a fog light mod for the 3g. Im talkin about the one where you can turn on just the fogs with the corners.
I'd like to do this too...if I understand what you mean. So, you want the fogs & corners to be on, but not the daytime running lights, correct? If you find out...lemme know!
B A N N E D
1 Post
Originally Posted by jay0k
What's the reason to do it?
cause it looks hot. this is how it looks on my car just to give u guys an idea and clear up any confusion as to what im lookin for
![](http://i20.photobucket.com/albums/b221/bimmerman318is/P1010170copy.jpg)
B A N N E D
1 Post
damn i forgot the 07s have DRLs. when u turn your corners on does the DRLs shut off? i havent had time to play around with his car.
AZ Community Team
Received 7,770 Likes
Fogs plus Corner lights (i.e. Parking Lights) is perfect for dusk. Just for that 1/2 hour or hour before dark.
I too wish the fogs were independent of the headlights.
look in the 3G garage, there is a way to make the fogs run independent of the HID's, though those are for the 2004-2006 TL, though you can figure out the diagrams to fix it for the 07 TL. Forgot to add that the 3G tl lights are controlled by a computer in the engine bay and not just wires and relays.
A J35A8 EG civic is in
Id also like the fogs to come on with the parking lights. Ive just never tried because its too complicated for me without a DIY. Sooo if you find out let us know how u did it.
i have the electrical book at home when i get in today ill look it up but to my knowledge its harder because it runs from the component switch to the computer n then back out again....somewhere theres a calculation being made by the computer.
Registered User
Black ur right but once it passes the computer theres a resistance on the line.....the sequence is like this....
Combo switch~~>computer (some sort of calculations being made) ~~> resistance added~~~>relay~~~>foglights. im sure if u crossed lines something would go....on the old TL it was direct connection.... switch~~~>relay~~~>Lights
its on the turn signal switch.... the only thing was the old tl had a couple of more wires only to indicate to the computer they were on and to turn the lil light inside the switch on
I have car ADD
yea. i know of the 2G & AVG accords its a button, isolated from the everything else, made it kind of easy (like u said, switch, relay, lights)
i think it seems like a cool idea to do this, but, i wouldnt want to be the first to start cutting wires up. maybe if we could get a clear wiring diagram we might be able to figure something out...
like you said that computer MIGHT sense something wrong, it may not. as im sure both lights are std 12V... so in order for something to go be sensed as "wrong" on the computer, you would need a bi-directional feedback from the lights back to the computer. which might be installed, if these cars have a "bulb out" indicator. i never blew a bulb in my 3G , so i wouldnt know.
the best bet possible may be to just splice the wires coming out of the fog light, and incorporate your own toggle switch to power them on & off. the switch, may look a little ghetto, but it might work!
i got a hook up for super cheap HIDs i wonder if people would be interested... anyone? and they arent junks ones either i havent had one problem in the past year with em... i just came across a distributor....yea.... they do sense a voltage drop i dont know if its from a resistor or something else im stilll looking into it..I havent had time the past couple of weeks because of work but by the end of next week, u better believe im gonna sit down n work on a work around.....if its electricity theres a work around....even in the book it shows everything running into the computer....ill do it ill be back
i really want to do this too!
if im reading the factory etm correctly the only reason it goes through the ecm is for the auto function! i will ask some of the old heads at work to look at it with me on monday to get there input! i will updade soon!
if im reading the factory etm correctly the only reason it goes through the ecm is for the auto function! i will ask some of the old heads at work to look at it with me on monday to get there input! i will updade soon! ![Wish](https://acurazine.com/forums/images/smilies/wish.gif)
ok well I looked into it and its no big deal to wire it up somewhat in the style of the 2nd gen but here is the problem.... in the manual it specifically give a diagram and explanation and shows things that are monitored n controlled...
"The ECUs on the BCAN and FCAN transmit and receive information in the form of structured messages that may be received by several different ECUs on the network at one time. These messages are transmitted and received across a communication circuit that consists of a single wire that is shared by all the ECUs on the circuit. Since messages on the FCAN are typically of higher importance, a second wire is used for communucation circuit integrity monitoring (500kbps). A backup circuit is also added to the headlight and wiper circuits on the BCAN (33.33kbps)in the event of a network wire or ECU failure that would effect the operation of the system"
in the diagram is shows that the gauge cluster is in the middle of all of this and it spilts operations in BCAN AND FCAN. on the BCAN side these are the units ( COMBO SWITCH CONTROL UNIT, MICU, RELAY CTRL MODULE, DOOR MULTIPLEX CTRL UNIT, DISPLAY PANEL CTRL UNIT, POWERSEAT CTRL UNIT, HFL, POWER MIRROR CTRL UNIT) on the FCAN (ECM/PCM, VSA, NAVI UNIT, AUDIO UNIT) and at the end of all that theres a GA-NET wire tht Im sure links it all together.
THing is when you look at the fog light relay schematic all the wires from the combo switch run into the MICU and the combo switch CTRL unit considering what it said in the statement above, the circuit would somehow be bypassed if its tampered with by the ECU. can anyone else concur or just make what their saying wrong?? lol its in the service manual for the car it pages 22-89 and 22-174
under renovations....
Would it be easy to just get a foglight wiring kit from pepboys and use that from th3e back of the lights and tap it back to the wire on the combo switch. You could just cut the wire before the switch and run the wire from the kit to the stock one for the oem look.
keep in mind I haven't seen the switch in the tl yet as I don't own one but I have used the foglight wiring kits in my teg. I used them for my fogs and yellow bulbs I put in my high beams as drl's
The Golden One
![](https://i20.photobucket.com/albums/b221/bimmerman318is/P1010170copy.jpg)
![](http://www.anyyouth.com/ilya/Maxima/Final%20Detail%20of%2007/Picture%20058.jpg)
![](http://www.anyyouth.com/ilya/Maxima/Best%20Of%20Pictures/32.jpg)
![](http://www.anyyouth.com/ilya/Maxima/Best%20Of%20Pictures/54.jpg)
![](http://www.anyyouth.com/ilya/Maxima/Best%20Of%20Pictures/57.jpg)
Back to the original thread...I think this look VERY nice on ANY car. You don't waste your bulb life, and since our cars have HID's (I have custom headlights - they have TL Bi-Xenon projectors in them) it doesn't shine a bright light at a person coming at you (although during the day it's not AS bright it's still bright).
On my Maxima...this was accomplished by cutting a wire having to do with the fog light (I forget which one as it's been a year since I did it or even looked at the instructions) and splicing it with the wires running from any of the corner lamps. Very simple, too bad the TL is so advanced.
Another benefit of this is, seeing as I live in the country, I can have my high beam HID's on AND my fog lights, providing even more light. Usually, the fog lights go off when a car turns it's high beams on. Not on my car.
quanaman
01-09-2023 07:33 PM
InFaMouSLink
10-27-2015 06:52 PM
lanechanger
10-13-2015 10:56 AM
