Fog light bulb part number
One of my fog light is out (burnt out bulb presumably). I want to replace the bulb and since I’m only changing the bulb for one of the lights I need to replace it with the same OEM part so 2 fog lights look the same.
I searched around on the web and here and it seems that the part number is #33116-SL0-003. However I also came across of a number 33115-S84-A01 and I’ve seen references to H11 and 9006 in the same context. So it’s a bit confusing.
I want to make sure that I’m getting the correct part. Can someone help me with this?
H11 if 07/08. I have no idea if 04-06.
it seems that 9006 type has multiple subtypes. Sylvania has this subtypes listed:
SilverStarUltra
SilverStar zXe
SilverStar
XtraVision
EcoBright
Standard
I assume the "standard" is the one i would need to match the other OEM fog light:
SilverStarUltra
SilverStar zXe
SilverStar
XtraVision
EcoBright
Standard
no you weren't but you would get the right one, this is what I found from a 30 second search...
05 original part # 33116-S84-A01 has been replaced by #33116-TA0-A01
you might need to get both to match brightness and color...
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
