Flush 5at?
Old May 6, 2013 | 02:38 PM
DominicTl06's Avatar
Flush 5at?
Hello, I want to know how to change the transmission oil (Flush). And if someone explains it to me in French it would be good. Tank you
Old May 6, 2013 | 02:43 PM
pohljm's Avatar
not in french, but you do not want to "flush" by connecting to a machine. that's not recommended for this transmission. You should drain and fill manually. it holds much more than you can drain, so its a multiple drain and fill procedure. 3 quarts out and 3 quarts back in. Perform that 3 times and drive thru the gears in between each drain/fill and you will have replaced the majority of the fluid. This is referred to as a 3x3 around here.
Old May 6, 2013 | 02:45 PM
SharksBreath's Avatar
BANNED
Old May 6, 2013 | 02:47 PM
lusid's Avatar
FTW
LET'S BE NICE EVERYONE!
Lez e comp pe dong (from home alone) that's all I have for french.
Use Redline Oil, Please perform a search function on "transmission"
Prepare to read for days.
Good luck
Old May 6, 2013 | 02:53 PM
Joneill44's Avatar
Great read if you have the time
https://acurazine.com/forums/showthr...ht=optimal+atf
Old May 10, 2013 | 02:11 PM
Okay thanks for answer.
BOOSTED6IX-S
Feb 22, 2016 01:53 PM
adrian_s2k
1G RDX (2007-2012)
23
Jan 12, 2016 04:25 PM
hashbrown
Sep 29, 2015 12:13 PM
Ratheruneeq
Sep 28, 2015 07:41 AM
STL TL-S
Sep 23, 2015 08:52 PM
