floored my TL for the first time today
on the way back home from my rotation, i, for some reason, said what the heck and decided to FINALLY floor my 2 months old WDP TL (2200 miles). the acceleration was great....felt the VTEC engine power in as my foot was deep in to the panel......but i must say i was little disappointed at the pick up speed once i hit 60miles....i guess i was expecting my head to be glued to the headrest due to the 270 horses of accerlation but my body barely moved back as i sped up to 100 miles in 3rd gear.......so that was little disappointing but i guess with all the weight that TL has, i was overexpecting myself....plus my old car had 150 hp so i had a bigger expectations......but overall, it was exhilarating experience!!!!!!
https://acurazine.com/forums/showthr...34#post1255634
"..i guess i was expecting my head to be glued to the headrest due to the 270 horses of accerlation"
ck the link above turns out it is 258 hp not 270
But they will put down near identical numbers at the wheels, given equal conditions.
People need to stop making a big deal out of the new SAE standards. It's not that big of a deal.
Originally Posted by BloodFart
Officially his two-month old '05 (I'm guessing it's an '05) still has 270 hp at the crank. It's the '06 that has 258.
just an attempt at humor
Not a Blowhole
Anyone thought of gearing? The intermediates are not very low in this car - they are for smoothness and good fuel economy.
I loved the "overexpecting myself" term - that is a new one.
Few cars will glue you to anything above 100 mph. I recommend SuperGlue gel liberally applied to the back of your head.
I have not had the car long enough, but I know there is a sweet spot
in 2nd or 3rd gear where you really feel the power.
I was out one night shortly after I got the car, without the wife, on a
twisty road, and gave it a lot of gas at a moderate speed and felt
the power.
At other times I have floored in and it did not FEEL as fast, even though
I let it get to much higher rpm's.
I was going FAST though, and already have to many points on my licence
from the motorcycle....
Very moderate applications of the throttle in any sort of turn seems
to upset the crappy stock tires though!
After the engine gets well broken in, and I get used to the car, I need to
play a bit.
As it is, I get to drive it a bit on weekends (with the wife), and have
not pushed the car at all, or even figured out how to launch it
from a stop briskly.
I know I could get into some serious trouble with this car though...
Brett
the power.
play a bit.
Brett
Fightin' Texas Aggie
I love the fact that I can take off from a stop, but I hate doing it cause I look down afterwards and I swear the needle has moved a notch down on the fuel gauge.
I had fun outrunning S430, Camry V6, Taurus SES, 4Runner V8, Saab 9-3 and more on 10+% grade in 2nd gear hitting 5500RPM+ (5AT). With two passengers and full load of tents and blankets and food and water. I wasn't letting anyone pass me. As soon as someone was coming close in my rearview mirror, I changed to 3rd and floored to 90MPH
I was doing between 50MPH - 90MPH on hilly curvy road most of part. It sure ate lot of gas even I had Shell V-power with 92 octane in tank.
lol they all have 258... it was all marketing mumbo jumbo... If it is all true I am sure acura is scrambling to put a spin on why the drop and that the engine really produces what they claim...
The gearing can make a big difference. As far as being disappointed. well some people expect more from the car.
Team Anthracite Member
I have the same experience - I have not paid attention to the exact RPM at the time, but there is definite points where I have felt gradual acceleration and other times where I feel myself hanging on and pressed into the seat. Probably when the RPMs are 3000 and I mash the gas is when I get it to really kick - maybe 2500. Somewhere around there - I usually don't notice cause I am laughing and grinning too much. Car has some balls.
the power.
play a bit.
Brett
the power.
play a bit.
Brett
Try this when you are going on an empty road at around 30-35 mph in the 4th gear, floor the car, the car will downshift quickly into 2 or 3 and will give you a burst of power I sometimes do it to make lights (ahem
I have been dissappointed as well while flooring the car from a stop position, maybe that is because of only the 238 lb/feet of torque...
Team Pumkin
Originally Posted by JohnDoe2
Did you turn off the VSA before flooring it? I was told if you need to turn it off to squeal the tires....never tried it though.
BD
Originally Posted by RAdams
270hp was not marketing mumbo jumbo. The engine made (and makes) 270hp according to the old SAE standard that everyone was using. There is a NEW SAE standard that Honda has voluntarily chosen to adopt. The 06 does not make one hp less than the 05, much the same way that 99 degrees farenheit does not become cooler when expressed as 37 degrees celcius. The number is different because the standard is different.
It's called PATHETIC.
Registered Abuser of VTEC
Originally Posted by Steel
Yet GM has been doing this already, and the lower end GTP was accurate in reading. (Similiar class).
LOL ok believe what you want. Sure they voluntarily adopted the new standard so they can claim less power.. Are you listening to all this.???....
But people make purchase decisions on advertised HP ratings. If they advertise 270 and make 258 that is quite a drop. Now the Corvette gained 5 pnonies.. Which goes to show you that you need to get with it. I would like to see how many other companies lose as much as honda does. So honda does their testing on a minimal standards that will give them a better marketing position.
Wake up be a wise consumer and do not believe the hype. I am sure you have a better sex life because of the car as well. lol.
Registered Member
When you have a car that will break traction (spin the tires, gentlemen) in 4th gear (4-speed transmission, 3.54:1 rear) at 100 MPH, then, my friends, you really do have a screaming machine.
(source, November, 1965 Car and Driver road test of the 1966 427 A/C Shelby Cobra, 485 HP, 480 lb/ft of torque, 2850 pounds).
I never said it made less power.... lol
You don't understand the new OR old SAE standards -- I suggest you read up on them. Educate yourself. This will affect EVERY manufacturer -- some cars will gain a few poines, some will lose a few. Not everything is a conspiracy.
TLDude876
12-28-2016 03:18 PM
acura_dipset_tl
01-01-2016 03:02 PM
