First Time Oil Change
So I'm strongly considering performing my first oil change on my car. I'm going to go with Redline Synthetic Oil so I went to JEG's website and typed in 2005 Acura TL and it recommended 5w30. I know the manual calls for 5w20 so I'm wondering which one should I go with? I'm also going to get a K&N oil filter, a 3.5 ton floor jack, and a pair of 3 ton jack stands. Any thoughts or advice would be appreciated
Oil change takes like 2 seconds in this car its easy and straightforward just dont overtighten the drain bolt and the filter should be pretty much hand tight. No need to retighten with an oil filter tool.
AZ Community Team
Received 7,770 Likes
My thoughts exactly.
C-004: DIY: Oil Change Checklist with Service Manual Scan
https://acurazine.com/forums/showthread.php?t=80273
https://acurazine.com/forums/showthread.php?t=139528 with pictures
I'm going to use a torque wrench for the drain bolt. Should I expect to be able to remove the old oil filter by hand? The one on their isn't oem so it probably wouldn't make sense to buy the honda oil filter tool
AZ Community Team
CAFE is about gas mileage. The whole Acura model range has to meet some EPA average for mileage. For them to squeeze out a little extra, they use 5W20. It's just a couple tenths of a mile per gallon, but average across all cars sold, those couple of tenths matter. For you and me, those couple of tenths of a mile per gallon are meaningless. That's the theory anyhow.
IMHO, 5W30 should provide marginally better protection with no noticable difference in gas mileage.
AZ Community Team
If so, drive a screw driver though the old filter and twist it off.
If you do your oil changes properly, you'll never have that problem again and a filter wrench would just sit in a drawer and gather dust.
Registered Member
You should have a supply of drain plug washers handy for this job. The torque for the drain plug is 29 ft/lbs, or 360 in/lbs, and most definitely use that torque wrench.
Before removing the drain plug, remove the oil filler cap. This promotes a smooth flow of the oil oil into your oil drain pan.
When it comes time to remove the old filter, slip a 1-gallon heavy duty ZipLock bag up over the filter and pickup arm once the filter is loose enough to remove by hand, then finish removing it. This will keep the residual oil in the galleries leading from and to the filter from spilling on your suspension system, the floor of your work area, and you.
Make sure you spread a thin layer of oil on the new filter's rubber gasket and clean the pickup face with a paper towel - making certain that the old filter is not stuck to the pickup before you install the new filter. Tighten the new filter 3/4's of a turn.
Install 4 1/2 quarts (U.S. of course) of your new oil then when finished, start your engine, let the oil pressure light go out, and check for leaks - especially around the filter.
Reset your oil life display on your MID and you're done.
Coal
If this is your first time doing your OWN oil change, you going to need that tourque wrench to get the drain bolt off. it was pretty obvious that when the previous owner took mine in to get an oil change, the grease monkey used a friggin air gun to put it back on. took me about 10 minutes to get it off with a socket wrench. just fyi
You may want to replaced the drain plug with one of these:
http://www.amazon.com/Dorman-092-013.../dp/B000IZ48RS
It has it's pros and cons.
Pros: Never had to remove the drain plug and risk stripping the oil pan
Don't have to fight with the drain plug to get it off
Don't have to worry about replacing the washer
Not as messy
Cons: Slower draining
May not quite get all the oil drained, but close enough
If you order one, make sure you get the correct size. I find it makes the oil change a little easier. You can find them at O'Reillys. Just a suggestion. Have fun with your oil change.
Not as messy
Registered but harmless
Received 1,106 Likes
Otherwise,
![Agree](https://acurazine.com/forums/images/smilies/agree.gif)
![Scratch](https://acurazine.com/forums/images/smilies/scratch.gif)
The torque wrench may be useful for measuring the amount to tighten the bolt back up if you're not used to using a wrench, although I've always tightened by feel using a ratchet.
AZ Community Team
I'll occasionally put a bit of grease on the latches and hinges. If you've got aftermarket sway bar bushings or end-links, they may have grease fittings.
Always good to use a rubber lube on all the rubber bushings under the car, front and rear as it helps to keep them pliable and not dry out. I use it at every oil change on all the cars:
http://www.agscompany.com/lubricants/canadian/213
Although an oil filter wrench is not the norm when installing the filter, I mark the filter, turn by hand then give it a tweak with the wrench. Actually one of our cars is 1 full turn after the rubber seal makes contacts.
Registered Member
I disagree with using a filter wrench to install the new filter-- it should be hand tightened.
Otherwise,
with everything else in SouthernBoy's post.
I've always been able to get the oil change bolts off cars with just the ratchet wrench, and maybe a small handle extension.
I don't think grease fittings exist in most cars anymore; I thought most joints were sealed for life (or until boots rip...
Otherwise,
Well...Some things I might want to say take it or leave it...
1. NEVER use a torque wrench to break a bolt loose. Get a breaker bar or use a decent 1/2 in drive Ratchet.
2. I hand tighten my filters and I have had no issue...never had to use the tool.
3. Lubing the chassis I do not really do...What I do is I inspect for leaks and make sure balljoints and so on dont have ripped boots. I also check play in the front suspension.
Thats what I usually do for a simple oil change.
I was looking for drain pans and I came across this: http://www.griotsgarage.com/product/...d+extractor.do
What do you think?
What do you think?
AZ Community Team
What do you think?
What do you think?
I wouldn't. I'd rather drain from the bottom by gravity, than hope to suck everything out the top.
WallyWorld or any auto parts store will have a simple oil drain catch pan that'll hold ~7 qts for a few dollars. That plus a funnel.
Put your old/drained oil back into the now empty "new oil" container(s) and drop 'em off at you local oil recycle/collection place (for examply, my local Firestone takes used oil).
Something like this:
![](http://gas-cans-4you.com/oil-change-accessories/images/GAS-11838.jpg)
Registered Member
Don't forget to warm up your engine a little (not to normal temperature) so that you get a better drain. What I do is start out cold, as on a weekend morning, and drive about 3/4's of a mile around my neighborhood. That warms the oil up some but does not make it hot. Don't want hot when you're doing an oil change.
Yeah, I was either going to drive it slowly around my neighborhood which is a little less than a mile, or if I was coming back from a longer drive, just let it cool off for roughly 10-15 minutes. I'm planning on doing it this weekend. I have everything I need except for the bolt washer, which I will pick up at the dealer
Registered Member
AZ Community Team
Good post, as i'm interested in doing same with my car. My 05 TL car has been to the dealership since new and now has 71K miles on it.
As I want to keep this car around for a while longer, any thoughts on moving to a synthetic? Is it too late, should I have done it earlier? Should I do a flush first and if so what's recommended?
mada51589
05-03-2022 08:54 PM
Zonian22
11-14-2015 01:20 PM
