Fantastic results from Mobil-1 syn ATF
Keep'n it clean- Orlando
So the other day I changed my engine oil, while I was as it I picked up 3 quarts of the mobil-1 fully synthetic ATF fluid for about $9.97 a quart....
NOTE: I have a AUTOmatic trans, not manual.
The trans fluid was changed about 4-5k ago and it just felt like it was having some rough shifting, every once in a while I would feel the "double bump" going from P to D, the horrible jerk the TL is known for from shifting from 3rd to 2nd seemed like it was back.
So I drained the Honda fluid and put in the Mobil 1 (3x1) and I can notice a huge difference!
Shifting is MUCH quicker, precise, and almost un-noticeable.. the car went from shifting like most TL's do to almost not being able to tell when its shifting... basically like butter.
I can tell this fluid has changed the shifting, making it feel a lot quicker, direct, precise and dramatically has reduced the head whipping that most TL's do when shifting under full throttle.
Down shifting from 3rd to 2nd is now a DREAM.
All this was achieved from a simple drain and refill, I can only imagine the amazing results obtained from doing a full 3x3.
I plan on just changing this fluid each oil change so I dont see the need to break my back half a day doing a 3x3....
thought I would fill you guys in on a great fluid... enjoy.
I personally believe the tranny failures come down to user abuse and error... there is no way Honda would build great cars and skimp on a fluid.
Regarding what you said however, I also believe there is much better out there, and I believe I have stumbled across it... you should def go get some of this mobil 1 for 3o bucks.. the trans becomes a dream.
Yeah I have been back and fourth about redline.... I actually at one point considered trying the Type F, but redline themselves told me not to use that in our trans so I agreed, listened, and didnt assume I knew more then them "like some on here" and did not go that route.... I considered the D4...but guess I just never really got around to it... looks like mobil-1 is pretty good so I guess problem solved.
I really dont think that z-1 is really that bad, I mean look at it from Hondas perspective that sells cars based on "reliabiltiy" would you put a crappy fluid in your trans and not care?
I also personally believe if Z-1 wasn't a bad fluid, why did they stop using it and start using another?
Additionally, ATF aside, the GM MT fluid literally CURES their issue, and from what I gather it's not even really debateable. What's the deal with the Honda fluid there then?
2007 TL Type-S NBP
Yes down shifting from 3rd to 2nd and upshifting from 2nd to 3rd is now a dream, smooth and effortless...I would say close to a 90% reduction in the jerking motion with the transition of the gears both up and down.
Well you have the full review today, Ill update a month from now, but something tells me this fluid is not going to break down as fast as the z-1. I am also just going to incorporate a trans flush with fresh mobil-1 fluid each time I do an oil change, hey for another 30 bucks, there is no reason we all shouldn't.
Glad to hear it's treating you well so far!
I'm going to try the same thing =)
Redline is impossible for me to find =(
UA7 6MT
Check out your local store for stock.
Anything is better than the junk Honda puts in there.
3x3 ATF Flush with Amsoil ATF was one of the first things I did for my AT.
You could feel the shifts being cleaner and the engine just operates more smoothly.
Chapter Leader (San Antonio)
No one really knows about that mobil 1 fluid you put in, did you even check the viscosity and such to see if they were similar to Z-1 or DW-1?
I know, I broke my rule in responding to an ATF thread, but needed to suplly additional information.
If you read some threads a while back, I also spent time with the tech reps at both Redline and Amsoil and both said NOT to use the Type F as replacement for the Z-1.
That's a Dexron/Mercon replacement not intended as replacement for the Z-1. In fact, if my memory serves me correctly, I believe the owner's manual states that Dexron is to be used only in an emergency situation and that once to the destination purge the Dexron from the system.
From the Mobil 1 site, NO application for the Honda/Acura.
Mobil ATF D/M
"Mobil ATF D/M is recommended by ExxonMobil for use in 2005 and earlier GM vehicles. Mobil DEXRON-VI ATF is recommended for 2006 and newer GM vehicles and for improved performance in 2005 and earlier GM vehicles, wherever DEXRON is specified. Mobil ATF D/M is also recommended by ExxonMobil for use in 1988 and newer Fords, except vehicles that require MERCON V or Type F ATF".
Got to realize that a different trans fluid with cause the shifts to feel different, but does this indicate that the fluid is a better fluid, not in my book. Every manufacturer creates their fluid for a specific application and as far as the aftermarket, I wouldn't use any product not recommended, but as Red Line D4 is a direct replacement, that would present no problems.
At least with the Type F fluid Innacurate and a few other members spent time on the phone with redline and their engineers and found out that the Type F fluid was the same as D4 without the Friction Modifers.
Mobil ATF D/M
The bottom line on this Forum seems to be to use whatever suits your fancy regardless of the applications designated by the ATF manufacturers, as well as the car manufacturer.
Once again my apologies.
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
