European Mods
European Mods
I have an 05 TL Navi with just under 70,000 miles. Next year I'm planning on moving to Sweden and I'd like to ship my car there, can anyone tell me what mods I'll have to make so that I'll be able to drive it there.
Thanks,
Scott
Thanks,
Scott
You will need a supercharger and a nice set of 18 inch wheels. Legality wise, check to see what side of the road they drive on and if the TL meets their DOT standards like day time running lights.
If you need DRL's, you can just make the inside aspect fog lights your DRL's, and if you want them as fogs, they will always be on with the headlights. Alternatively, you can have them switched and have the Accord foglights mounted in the lower grilles.
The taillights are LED but the turn signal that he needs to change is just a bulb. you can always send out tails to get customized with a yellow turn signal.
I think you need to prepare North weather
1. Check and if necessary change coolant
2. block heater
3. Weather tech floor mats
4. Rust corrosion prevention bottom car
5. Check and in needed change motor oil
6. Set of winter/summer tires.
before doing that I suggest check forecast in the area where are you going, what kind of roads there?
Possible find forums Honda enthusiasts in Sweden.
May be you need Jeep or SUV There? Again depends of the area
Acura is only USA brand. Honda doesn't have it in Europe.
IMHO:
Check the budget. May be easiest way to sell your Acura here and get Honda Accord there (same as Acura TSX)
www.Honda.se
Regards,
Dmytry
2. block heater
IMHO:
www.Honda.se
Regards,
Dmytry
Jul 16, 2017 07:33 AM
GWEEDOspeedo
Jan 15, 2016 10:39 PM
InFaMouSLink
Oct 27, 2015 06:52 PM
