Engine mount and timing belt
Old May 29, 2012 | 10:42 AM
sara's Avatar
Hi acura fans
need some advice. i took my acura 2004 tl for service and the dealer mentioned my front bottom and passenger side engine mounts are broken and i need to replace- he quoted 800 and mention dits about 4 hrs worth of labor.
can anyone adv another suggestions since its an expensive affair
also he suggested to change the timing belt & water pump which would be about 1000/- Do i need to change it ...
Old May 29, 2012 | 10:50 AM
VanyDotK's Avatar
More details, how many miles are on your car?
Old May 29, 2012 | 10:58 AM
lilsid112's Avatar
Thats extremely steep for just a timing belt and water pump. Check to see if he's replacing any of the pulleys as well with that price. Theres a thread around here, where you can buy the entire timing belt kit for 300. Also check out a local mechanic, if you don't know any ask a co-worker, or friend. Depending where you live, I believe there is a dealer offering to do the 105k fairly cheep. I think its Hamilton Honda in NJ and just ask them to replace the tensioner pulleys and idler pulley.
Concerning the motor mounts I know the front and rear are a pain. When I did my timing belt service, the dealer went ahead and replaced the side mount. They didnt charge me labor since they were already in that area working. New mount was $8X.00 for the side, but I'm not sure about the front.
Edit:
Heres the dealers site:http://www.hamiltonhonda.net/specials/service.htm
Old May 29, 2012 | 11:26 AM
ez12a's Avatar
the overexplainer
1000 is about right from a dealer (minus the $380 deal in NJ). That would include the pump, tensioner and the belt.
800 is pretty pricey for two mounts. side mount can be done in 30 minutes or less. Front mount will take a little longer but you can save hundreds DIY.
Old May 29, 2012 | 03:47 PM
swoosh's Avatar
takin care of Business in
^^^ THIS !!!
ask the dealer how much only for the labor and take the parts yourself....
or find a mechanic and do it that way....
if you are in KS send me a PM and will help ya....the mounts should not take more than 1-2 hours and they dont cost as much....Timing belt sounds about right....
+1 on more details on the car...
Old May 29, 2012 | 05:32 PM
ep3kid914's Avatar
800 for just mounts are pricey i changed my 3 motor and 3 transmission mounts for 250 in my 04 tl all i had to do was buy my own which was like 4xx online
Old May 29, 2012 | 11:17 PM
Bruce Banner's Avatar
At what point in time do the 04 motor mounts go out?
Roughly every 150K mi?
Old May 30, 2012 | 02:48 AM
ghettocrxsi's Avatar
You can buy all 5 mounts for less than 500 dollars with no discount though the dealer. And the whole timing belt setup with water pump and everything you need can be had for less than 400.
Take it to a honda/acura specialist in your area to get a better price. I just bought all the items for my type s with a nw power steering line and all the parts to rebuild the pump for 800 shipped.
Old May 30, 2012 | 09:22 AM
6MTProwler's Avatar
Death Before Dismount
Just had my timing belt done about a month ago and I had to replace a side mount at the same time... So it's safe to say they go in conjunction with the timing belt.
Also, I only paid 850ish or so for the entire job.
vaughanml2
Nov 1, 2021 10:16 AM
drone619
Jan 26, 2016 07:09 PM
redsox68
Sep 16, 2015 06:18 PM
merc009
Sep 14, 2015 06:43 PM
asahrts
Sep 4, 2015 05:55 PM
