emblem removal
Old 11-11-2009 | 11:44 AM
tinad2004's Avatar
wishing for a GT-R
emblem removal
i tried to search for a few results but nothing came up that i found helpful, i was wondering if there is a step by step DIY on how to remove the emblems because i was planning on painting my emblems black but couldnt find the diy thread, if there is one just post it and mods can close this thread. thankk you
Old 11-11-2009 | 12:12 PM
ZhenyaF's Avatar
Off roading in his
Do you want to remove the rear "acura and TL" emblems?
If so, then just heat them up with a hair fan and pull them off with tooth floss or fishing line.
The "A" emblem on the back has 2 holes behind it, I would suggest to cover them up with electric tape, while you're getting it painted.
Another suggestion - after I removed the emblems on my car, I could still see the TL and the Type S faintly on the trunk, that helped a lot when putting the emblems back on.
Old 11-11-2009 | 12:28 PM
tinad2004's Avatar
wishing for a GT-R
oo ok , thanks a lot for a quick response. ill try that this weekend
Old 11-11-2009 | 01:30 PM
ggesq's Avatar
Here are some links to threads that were posted in the 3G Garage. Please look there, alot of other good info in the Garage.
https://acurazine.com/forums/3g-tl-2004-2008-93/de-badged-3g-garage-e-016-a-553862/
https://acurazine.com/forums/3g-tl-2004-2008-93/i-am-rebadging-anyone-have-map-where-badges-go-3g-garage-e-016-a-580712/
https://acurazine.com/forums/2g-tl-1999-2003-98/how-remove-badging-pics-vid-inside-3g-garage-e-016-a-581721/
Old 11-12-2009 | 09:16 AM
04WDPSeDaN's Avatar
iWhine S/C 6MT TL
Pm me if you need help. it's easy to do but you will need to clay then compound and finish with wax afterwards.
Old 11-12-2009 | 10:24 PM
tinad2004's Avatar
wishing for a GT-R
thankk you guys ! and if anything u will be receiving a pm haha
Old 02-03-2010 | 08:55 AM
Crestwood1001's Avatar
How do you get to the bolts to take off the "A" i just wanna paint it and put it back on...
Old 02-03-2010 | 10:11 AM
dwb993's Avatar
https://hondacuraworld.hostasaurus.c...goldemblem.pdf
^Those are the instructions for installing the gold Acura emblems, but they include instructions on removing the existing ones, both front & back.
Old 02-03-2010 | 10:33 AM
It only says you have to use string around the A? I guess you just pop it off? I dont get it people say there are holes so I dont know what the deal is
Old 02-03-2010 | 02:51 PM
dwb993's Avatar
There are 2 posts that come off the emblem and are held in place by 2 clips with foam gaskets to prevent leakage. Use floss to unseat the adhesive and pop the emblem off. If the clips do not come out of the trunk, use needle nose pliers to gently remove them from the holes. If you cannot replace the emblem immediately or are removing it permanently, cover the holes with electrical tape to prevent any rust from starting until you can fill the holes in (or replace the emblem).
iRaw
ILX Photograph Gallery
30
08-05-2016 04:41 PM
LogicWavelength
3G TL Photograph Gallery
33
11-01-2015 09:38 AM
dainmezron
10-16-2015 06:56 PM
lowgrowl
09-26-2015 05:18 PM
Dman00tl
2G TL Photograph Gallery
09-25-2015 10:34 AM
Quick Reply: emblem removal
