Dynomax Resonator?
Got mine at Summit also. You're going to love the sound.
Being an Acha Bacha in
That's what I have, and I have this weird hissing/rasp sound ever since I installed and no one has been able to figure out why. I'm the only one who seems to have it, and I've checked the welds and for leaks and nothing. The sound only comes during the 2-3k RPM band and then disappears, its weird.
What do you mean to get 2.5 pipes because I didnt do this.
once you go black....
I think the 2.5 inch pipe he is referring to is to replace the mid muffler if you remove it along with the install of the dynomax (stage 3 exhaust). Any muffler shop should have this and you shouldnt need to buy it unless of course your welding yourself.
Its been a long time. I did the mid muff delete and Magnaflow res on my 07 TL-S.
I want to have the mid muff deleted and the Dynomax res put in my 06 TL manual, what size should the Dynomax be? 2.5" ? Is the OEM TL pipes 2.25" ?
What size Dynomax res should I get?
Thankyou. I did search around ???
http://store.summitracing.com/partde...0&autoview=sku
ON DA LOW CAR CLUB
They may look like glasspacks, but the Ultra Flow welded mufflers are made just for racing. Compact and lightweight, they have a 360 degree welded outer shell and a straight-through, wrap-welded, perf-tube design for maximum flow and minimum power loss.
thats from the web site.......
you lose power with this thing cause thats what it says
johnpancakes014
04-08-2016 06:47 AM
