Driver 1 vs Driver 2
Old Jun 28, 2004 | 04:55 PM
newacuraforme's Avatar
Isn't the TL supposed to change the heating and air-conditioning settings with Driver 1 and Driver 2 profiles? Maybe I am confused on this one? help?
Old Jun 28, 2004 | 05:00 PM
mastertl's Avatar
I don't have a Ferrari in
yeah it is. does it not change for you?
you have to set it differently every time you change the temperature settings or else it will just go back to the temp you set it for the first time.
Old Jun 28, 2004 | 05:01 PM
rets's Avatar
Moderator Alumnus
Wish this could help...
Originally Posted by Ron A
Just to clarify, it only adjusts the settings when a different key fob than the one that locked the doors is used. If you lock the doors with #1, and open them with #1, it will have no effect on the A/C. If you lock the door with #1, and #2 opens the door, the settings will be changed to the last climate control setting by #2, as TLGator said.
http://www.acura-tl.com/forums/showp...80&postcount=3
http://www.acura-tl.com/forums/showthread.php?t=85181
Old Jun 28, 2004 | 05:03 PM
Ron A's Avatar
Administrator
It only changes if the other fob was the last one to open the doors. If you lock the doors with your fob, then when you open them with the same fob, it will not change the settings.
Old Jun 28, 2004 | 07:03 PM
thanks
F-C
Motorsports News
33
Aug 22, 2018 09:53 AM
Mr.Tea
Oct 2, 2015 10:32 PM
hashbrown
Sep 29, 2015 12:13 PM
xsilverhawkx
Sep 28, 2015 06:51 PM
rhdune16
Sep 28, 2015 11:31 AM
