Door lock question
Door lock question
the problem is i can't lock the doors with the fob or use the driver's side door lock to lock the doors. i have to manually go lock all 4 doors. the fob will unlock the doors, tho. is that a driver's door actuator or a multiplex problem? or something else?
thanks,
scary
thanks,
scary
hey... check out this thread:
https://acurazine.com/forums/showthr...highlight=micu
i had the same problem a couple of years ago and the dealer changed out the actuator twice but that didn't fix the problem. they had to replace the multiplex unit. haven't had any problems since
Actuator
I had a similar issue over the last week. The beep and exterior light blinking when locking the car wasn't working...but did when I unlocked. I thought it was the multiplex gadget I read about on here but then realized it was b/c my front passenger door wasn't locking...the actuator broke. (although oddly, if I manually locked it and it remained in locked position after pressing unlock on the FOB, the exterior lights still blinked) Anyway, glad I didn't take it in for a multiplexer fix b/c that would have been more expensive and un-needed based on what I've read in the forums. I did price around and 1 dealer wanted about $250...the other wanted $299 plus parts. I found a shop close by that only does Hondas and has been around for almost 20 years. They use genuine parts...and did it for $108 out the door. I mention all this so that you don't miss the obvious issue (busted actuator) and you consider looking for a dealer alternative so you don't get price gouged.
tman570
Jun 11, 2019 07:56 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
wtf?
