Does your TL (TL-S) paint scratch easily ?
![Angry](https://acurazine.com/forums/images/icons/icon8.gif)
I've been seeing some scratches on my TL-S
after I washed it today for the first time since I got the car (new) last week...I really dont think its the materials I'm using to clean the car, as they are also used on my other cars which havent shown any signs of scratching etc.
I use a good sponge to clean down the car with Mr Clean autodry carwash, and use a microfiber towel to dry the car... I dont know if it's me causing the scratches or something else ???????
![Annoyed](https://acurazine.com/forums/images/smilies/annoyed.gif)
IMHO- based on what you said, it's the color bro. Get some Z-5 from Zaino.
triton3k...being that you have the same issue, I'm a little relieved that it wasn't just me/any of my doing...hopefully
I'm still surprised that this happens...I have a black Lexus LS and dont remember seeing these kind of scratches when the car was in brand new condition![ugh](https://acurazine.com/forums/images/smilies/ugh.gif)
So you guys are saying its normal to have/see scratches like this on a Black colored TL ?
A J35A8 EG civic is in
I have an 07 and I have alot of swirl marks. I dont really notice big scratches, but thats probably bc of the swirls. When the weathers really nice im gonna clay bar it to take them all away.
My Garage not
1 Post
i have a black tl too. the paint gets scratched when one piece of dust falls onto it when it's parked. then i get another scratch when i drive away and the piece of dust falls off.
:shakehead Scratches on a black car (or any) is not normal. I agree that its easier to see swirls on dark cars more than light colored cars, but swirl marks should not be accepted as normal.
If properly maintained, your car can be swirl free. LacViet (from 2G TL) is a very good example.
I suggest you guys head on over to the Meguiar's forum for details on how to remove swirls and maintain it.
I use a good sponge to clean down the car with Mr Clean autodry carwash, and use a microfiber towel to dry the car... I dont know if it's me causing the scratches or something else ???????![Why Me](https://acurazine.com/forums/images/smilies/whyme.gif)
Hey blazinginder,
When I used to wash my parents' cars (one dark green, the other black), I used the good ole' circular washing method (u know, "wax on, wax off" from Karate Kid? ). But its that method that makes swirls or spiderwebs (at least i think it is) cuz any little tiny dirt particles make circular scratches on the finish so when light reflects on it, it makes your car look sucktastic. Their cars, by the way, are riddled with swirl marks (thanks to me!). Anyways, I avoided that method and wash/wax my car using linear strokes (i.e. start from the top of the hood and move to the bottom in a straight line) and i make sure that i rinse the wash cloth after every stroke with clean water, and then dip it back into the soap bucket. After owning a NBP TL (like yours but without the benefit of the 3.5L
Swirls are inevitable and can be minimized. They usually occur during washes because of improper technique and equipment. See the AZ Car Care FAQ for proper washing techniques. You can remove swirls with a buffer (PC) using a polishing pad and a polish.
You are very misinformed about claying. A claybar will not remove swirls. Head on over to the Wash & Wax forum to get more info.
Majority of swirls come from the washing/drying protocol .. Ihave owned a few black cars and its tough but if done right you can just about keep them swirl free.. here is a few tips ..
Car washing
This is important as improper washing and drying methods is the major cause of scratching and swirling in the cars clear coat.
1. Hose the car down really well first and rinse it of before you wash
2. Washing: Wash your car when it is cool and in the shade. Air drying is the main cause of water spots, and the heat from the sun and the paint surface only amplifies the effect. Invest in a sheepskin mitt and car wash soap. Others will say different but as long as its not an el’cheapo bargain brand most car wash soaps are ok. Wash a panel .. rinse a panel. Its better to wash gently with more strokes than to rub hard and cause marring in the clear coat layer.
3. Final Rinsing: For rinsing, remove whatever nozzle you usually use from your hose, and rinse the car with the open end of the hose, with a low water pressure. You don't need a jet of water pummeling your car now that it's clean. Just let the water "fall" onto the surface, and you'll see the difference! Definitely helps with the drying process as it will pull the water off.
4. Drying: The Absorber and the MF towel are both popular for drying. I use just the Waffle Weave MF. Before you dry take the nozzle off the hose and with a gentle stream of water run it over the car, it will sheet 90% of the water off for you. I hold the first towel by the corners and pull it over the flat surfaces and it pulls most the water off then I use the MF towel to finish off the body. NEVER use the same Towel to dry the wheels/door edges as you will possibly fill them with crud and scratch the car in the next drying. Same reason to use a seperate wash mitt to wash the wheels. Get a cheapie mitt from WalMart for that.
Couple of tips you might find handy
a) I use the kitchen sponges that are yellow with the green scouring pad back to apply tire dressing. Spray the dressing on the foam side and apply to the tire .. no more overspray on your clean wheels or up on your paint. These are like $1 for 12 at your local dollar discount and at this price disposable when they get dirty.
b) Use Westleys Bleche Wite to clean your tires before applying your favorite dressing. Once you spray this on your tire you will crap when you see the brown crud run down. As with car waxing a well prepared black tire will look better when dressed up. If you have non-cleared alloy wheels protect them from the spray. This step is done immediately prior to the car washing step.
c) To apply your black trim dressing like Back To Black etc try using a foam paint applicator ( Foam wedge shaped brush on a plastic or wooden handle) to put the dressing on. This allows you to get in those hard to reach places and also great for doing straight edges on the rubber around the windows. Just make sure you wipe off the excess so the coat is uniform.
Car washing
Damn the start of this thread has me lookin at every possible detailing site and recommendations so my car looks good for the summer haha,
im such a loser.. but anyways http://www.detailuniversity.com/deta...x.html#more-20 is an awesome site that I found. They tell you almost everything you need to know, or at least what i wanted to know so far! Check it out.
btw I love NBP and I still dont regret buying a black car cause it looks soooo sexyy and everyone always compliments me and my car.
MetalGearTypeS
08-29-2016 08:28 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
