Does my Alarm Work?
Does my Alarm Work?
When i lock my doors with the remote, the doors just lock, no flashing lights, no honks, no beeps. I set the car to beep by the controls in the keyless settings. Any one have any suggestions? I was wondering if the alarm was cut before i bought it used.
After the doors lock does the car beep if you press the lock button again? (it's not a loud beep - after the first lock the car beeps on each subsequent push of the lock button that happens within 5 or 10 seconds of the first one)
Try this: open a window, exit the car, close the door, lock the car with the remote, keep the remote away from the car, reach in and manually unlock the door and open it . . . . this should set the alarm off (maybe before there is some sensor that picks up the immobilizer chip in your key) . . . . .
Have you tried pressing the panic button on the remote to see what happens?
Check the hood....Had a one time issue where the hood was closed, but the switch was acting weird and thought it was open, so it wouldn't arm or anything. Opened the hood and then closed it back and it cleared itself up.
The panic button doesn't work, and the window open, and open car from outside doesn't work either. But on another note, when i'm in the car, and its on, it still will detect correctly when the truck or hood is open.
So here is the problem. When the car is off and locked, it doesn't beep even thought the option is set no matter how many times i lock the doors with the remote, and also the stick lock security light doesn't blink, and also panic button doesn't work...
Thank all you for your time and help!!!
any one know why the security light by the door lock constantly would stay "ON" no matter if the alarm is armed or disarmed? the led stays on even when the ignition is on. anyone why this would be?
It actually does work. When i first purchased my vehicle i thought it didnt either. I tried sitting in the car after alarm activated and then open it, nothing happens. But recently for some reason when i sit in the car for a while, and i tried opening the door, my alarm would go off.
well, on mine the LED on the door just stay ON no matter what, but everything works like normal. can anyone check the manual to see what might be the problem? i'm selling the car soon and all of a sudden i get this problem. please help. thanks in advance.
Theres a link in the 3G garage to all the digital files of the car manuals. As well, if the car is under warranty, get the alarm checked out and other issues so the buyer can be more secure and happy that the car has been maintained.
Registered but harmless
Received 1,148 Likes
do you have a link to the car's manuals? it is an 04, and out of warranty.
The owner's and navigation manuals are linked from the 3G Garage to: https://techinfo.honda.com/rjanisis/...01_OMANUAL.asp
I don't think shop manuals are available, but you might try a search of the threads for the alarm issue and maybe door alarm light swap to see if there are any diagrams or photos. G/L!
couldn't find any info on the eom factory alarm. is there a fuse? where are the alarm components located? does the 2 wires that go to the door led have constant voltage or does it only have voltage when the alarm is on?
mada51589
05-03-2022 08:54 PM
Luis J. Rodriguez
09-12-2015 10:00 PM
ahsm
09-09-2015 08:35 AM
