Does anyone have 'Specific' Injen CAI Install Instructions without removing bumper?
I don't know about the Injen CAI, but I have the K&N Typhoon and I installed it without removing the bumper. All of the aftermarket CAI's are pretty much the same so I can't believe they would differ from each other. You can download the K&N instructions from their website: K&N Typhoon
Hope this helps.
Hope this helps.
One on the right for me
Hope this helps.
Hope this helps.
I also have the K&N CAI and didnt have to remove the bumper. While I dont have step by step instructions...
What I did was remove as much of the OEM intake/parts as possible...then removed the wheel and got rid of the splash guards. The hardest part was finding the little bolts that held the stock unit in place...once those were removed it was easy. Just feel around for them with your hand and then put a socket in there to get them out. Install took a little under an hour w/o removing the bumper and taking my time.
TL Driva
i just jacked the car up, put it on stands, took off the Front right wheel... unscrewed the wheelwell on the front side, folded it back, and then took everything out from there. like someone said earlier, its tricky to find where all the little bolts are, but u can figure it out when u just jiggle it around, and feel where its still holdin on... check out my site to see what the finish product looks like: http://www.cardomain.com/id/tldriva04 lemme know what u think, and how the install goes
VTEC HoooA
Can anyone with the K&N installed comment on the performance improvement experienced? I currently have the drop in, and noticed a decrease in the hesitation I used to experience when mashing the throttle, but little else.
Is there a large difference in the ambient noise at idle/full throttle?
Thanks in advance!
Thanks in advance!
Thanks in advance!
Thanks in advance!
I installed an AEM short ram on a 05 BMW yesterday, just for perspective, and the interior noise is really annoying. You can constantly hear the filter sucking in air, over the radio at times. If my TL sounded like that I would throw the intake away.
In short, if you are sensitive to noise changes or high pitched whistling sounds (at times) keep your windows up. As for the performance, didnt really notice anything, I did my mufflers and exhaust at the same time so I guess im not allowed to comment on this.
cycdaniel
12-17-2019 10:58 AM
Oakes
Wash & Wax
10-12-2015 11:17 AM
