Does the '04 TL have check engine light?
Sorry don't want to ask a stupid question here but here goes. I just bought a 2004 6spd, and unlike all the cars i have owned, when i put the key in and turn it on I don't see a Check Engine Light icon on the cluster. I'm afraid the previous owner removed the bulb to hide a code. I just want to make sure, does these cars come with check engine lights or do they just pop up on the small screen? The car runs and drives perfectly fine.
Thanks in advance!
Thanks in advance!
yes it does, if I'm not mistaken it should appear in the rpm gauge, might wanna check codes; thats odd
justnspace (11-26-2017)
Turning on the ignition to the ON (not start) should illuminate all the lights on the dash. I am aware of some dishonest car dealers who would remove the CEL bulb or even cheaper, they would take a very small (very small) drill bit and drill right through the front of the dash cluster and pop the CEL bulb (to avoid having to remove the dash cluster to remove the bulb). So, if your CEL is not functioning, you might look for one of these two possibilities.
The following 2 users liked this post by Crashmaster:
EvilVirus (11-28-2017),
It should be on only for a few seconds then turn off.
It's directly to the right of the headlight indicator.
It's not easy to remove the bulb as mentioned because it is soldered on, but it's easy to remove the cluster and open it up and cover up the SMD LED with electric tape and reassemble![Dunno](https://acurazine.com/forums/images/smilies/dunno.gif)
![](https://c1.staticflickr.com/9/8678/16090460253_abf1422d84_b.jpg)
teh CL (11-26-2017)
plug in an OBD scanner if you're afraid of hidden codes.
thank you everyone for their replies! im so glad forums like this is alive and well since facebook group pages have taken over!
Since i have a few vehicles I havent driven this and ordered the obd scanner. should be here tomorrow, fingers crossed.
Latent car nut
It seems Facebook has taken over many discussions of this type, unfortunately lots of information posted over there is effectively lost as it is very difficult to search for specific answers. Speaking strictly for myself, I'm hoping the pendulum swings back in favor of forums such as this. Time will tell.
justnspace (11-28-2017)
facebook groups ![Spit](https://acurazine.com/forums/images/smilies/spit.gif)
![rofl](https://acurazine.com/forums/images/smilies/rofl.gif)
![pofl](https://acurazine.com/forums/images/smilies/pofl.gif)
yeah those are just a bunch if idiots
Ahh the good old days of being rice and just pulling bulbs when they won't stop illuminating. Actually I am considering removing multiple lights on my e46, since I have permanantly removed and disabled the ABS,DSC, and the BRAKE light is also stuck on. Track car problems.
So plug in the obd scanner tool and surprisingly no codes. It still bothers me that I have no CEL on the cluster tho. are there any fix to this aside from replacing the cluster?
IF a code does pop up will the little screen tell me?
The MID doesn't show any codes for the engine.
What I would do is intentionally light the CEL. Unplug the MAF sensor and see if the CEL illuminates just to make sure.
Latent car nut
