To do, or not to do
To do, or not to do
Well i need some suggestions on what I should do. So i have to replace my radiator on my 6MT TL. I found a small corroded area that has old residue of a leak, and i have had to fill my reservoir every so often and just thought it was evaporating
, so before i pull it out this summer i want to replace it so it doesn't turn in to a big leak. My question is since ill have the radiator out should i just replace my front motor mount? I have no signs of bad motor mounts at all, but i have 145k miles and from what i have been reading these are a common issue that usually don't last even this long. I don't want to waste my money and fix what's not broken, but it may prevent the others from going bad if i did replace it, maybe
Is there any way when i can visually tell if i should replace the mount (Other than cracking)? Thank you, you all are always very helpful.
So if it is crack free and leaking no fluid then it should be good to go? Like i said i have no signs of bad mounts. I'm just on the fence if i should do this while ill have everything all torn apart. Or am i just wasting my time...
0utl (04-07-2015)
^ Thanks for that info! I dont mean to be annoying
i just want to be up on my maintenance, but from what i have read with engine mounts its more prevalent with the AT maybe? But with having no symptoms of bad mounts i may just take your advice justnspace. Thanks again everyone.
![Tongue](https://acurazine.com/forums/images/smilies/tongue.gif)
