To do, or not to do
Old Apr 7, 2015 | 01:09 PM
0utl's Avatar
To do, or not to do
Well i need some suggestions on what I should do. So i have to replace my radiator on my 6MT TL. I found a small corroded area that has old residue of a leak, and i have had to fill my reservoir every so often and just thought it was evaporating , so before i pull it out this summer i want to replace it so it doesn't turn in to a big leak. My question is since ill have the radiator out should i just replace my front motor mount? I have no signs of bad motor mounts at all, but i have 145k miles and from what i have been reading these are a common issue that usually don't last even this long. I don't want to waste my money and fix what's not broken, but it may prevent the others from going bad if i did replace it, maybe Is there any way when i can visually tell if i should replace the mount (Other than cracking)? Thank you, you all are always very helpful.
Old Apr 7, 2015 | 01:11 PM
i forgot if the front has liquid in it.
i know that when i took out mine, one was leaking. tell tale sign that it went bad.
Old Apr 7, 2015 | 01:46 PM
0utl's Avatar
So if it is crack free and leaking no fluid then it should be good to go? Like i said i have no signs of bad mounts. I'm just on the fence if i should do this while ill have everything all torn apart. Or am i just wasting my time...
Old Apr 7, 2015 | 02:07 PM
if its showing no signs of movement, nor is it leaking or cracked, i would let sleeping dogs lie.
Old Apr 7, 2015 | 03:00 PM
flyromeo3's Avatar
If it were me and I had the original motor mount with 145k miles i'd replace it.
Old Apr 10, 2015 | 01:14 PM
0utl's Avatar
Any more input from anyone with experience with these front mounts? How long do they normally last? Thanks!
Old Apr 10, 2015 | 02:01 PM
Oh Sickest TL's Avatar
Jeff
^^ prettysure mine need to be replaced I'm at 130k miles
Old Apr 10, 2015 | 02:12 PM
are you sure engine is not moving!?
the mounts are either broken or not.
Old Apr 10, 2015 | 02:15 PM
WDPanda's Avatar
On the TL sport (6MT), the front motor mount is different from the Base Automatic. It is a solid piece and not hydraulic.
Old Apr 10, 2015 | 03:11 PM
0utl's Avatar
^ Thanks for that info! I dont mean to be annoying i just want to be up on my maintenance, but from what i have read with engine mounts its more prevalent with the AT maybe? But with having no symptoms of bad mounts i may just take your advice justnspace. Thanks again everyone.
