DIY Spark Plug replacement???
Old Oct 5, 2010 | 07:51 AM
  #41
SharksBreath's Avatar
BANNED
Originally Posted by NSXRguy
Which vacuum line on the intake manifold can i use to feed the seafoam in????
you remove a plastic engine cover and a hose clamp and its hose- at TB to manifold-
the direction the metal nipple revealed when hose removed- may point back or sideways or front--if it will suck your finger on tight/ makes engine run smooth when covered, and has a hose clamp opened with pliers- not the screwdriver type...right place!
DONT shoot it down the hose!! it goes in the engine side thru the metal nipple
Last edited by SharksBreath; Oct 5, 2010 at 07:53 AM. Reason: added more advice, thx to a fellow AZiner
Old Oct 5, 2010 | 01:39 PM
  #42
I hate cars's Avatar
Wow, you guys are still doing seafoam through the intake. I'm disappointed.
Old Oct 5, 2010 | 01:43 PM
  #43
BANNED
lmfao...i haven't done it! i bought a couple cans, but haven't done it and probably won't do the intake, gas, crankcase till i hit 60k when i'll replace the spark plugs, and tranny switches.
you really hate this seafoam stuff huh?
Old Oct 5, 2010 | 01:45 PM
  #44
Is it obvious lol.
I just hate the way it's used and at the mileage it's used at.
It should not go in the oil since it's a solvent.
Nothing should go in the intake except for air.
Gas tank is fine.
Old Aug 12, 2011 | 06:26 AM
  #45
acurachampion's Avatar
It has to go into the manifold as a vapor use a hose and put it into the bottle. attached the hose onto the vaccum line either high vaccum port line or brake power booster vaccum line. take off from brake power booster. The line that feeds from the booster into the manifold. it just has to go in as a vapor. let it slowly work itself.
Old Aug 12, 2011 | 10:03 AM
  #46
How do you figure it goes in as a vapor? It goes in a large vacuum line and nearly kills the engine. It cleans by going in as a liquid and flashing off in the combustion chamber. What little cleaning it does do would be completely negated if it went in as a vapor. It's comical people worry about hydrolocking their engines when they install a CAI yet dump a fluid down the booster vacuum line.
Old Jun 28, 2013 | 09:15 PM
  #47
pohljm's Avatar
I had no I had a rough idle........ Till i just replaced the plugs at 93k! Noticeably smoother now, but it was such a gradual decline over time i had no idea. Plugs looked great.
cycdaniel
Dec 17, 2019 10:58 AM
Laoch
1G RL (1996-2004)
Oct 2, 2015 03:27 PM
gqdabien
Sep 8, 2015 11:41 PM
ellisd03tls
Sep 8, 2015 04:17 PM
NSolace
Sep 3, 2015 08:14 PM
