DIY LED Vanity Lights 04-08 TL
This was pretty easy, took me like 10 mins tops. Pretty simple all I used was a flathead screwdriver. Hope this helps some of you guys.
Vanity Lights
You will see where the flathead should go
There is a lil tab you will push then slowly pry down the cover. Note* Dont pry too hard you could break it.
Get the cover out
Remove light from harness by pressing tab and pulling
Theres a little cover you will take out.. Very easy to come out with the flathead
My bulb released very easy. Some may be hard to come out, use flathead to take it out. Be careful not to break bulb in there
Install LED bulb. Dont forget the little clear cover! Then put light back in same way it came out
And your all set.. I did LED conversion to the whole car, very bright, im very happy with them.
Hope this helps. Good Luck!
Vanity Lights
Get the cover out
Yeah I don't recall taking anything apart and the bulbs I put in look identical, plenty bright for that application. Does anyone else think it's stupid that the light isn't next to the mirror? When you flip the cover up it blocks most of the light... every other car I had the lights are on each side of the mirror.
Thanks bro. I pulled out the plastic cover because for some people the bulbs are hard to come out and to avoid breaking the bulb they should take that out.
cycdaniel
Dec 17, 2019 10:58 AM
acura_dipset_tl
Jan 1, 2016 03:02 PM
oyayjoe
Sep 12, 2015 04:40 PM
drewdeezy03
Sep 3, 2015 08:04 PM
