Disabling "auto a/c" feature
Does anyone know if it's possible to disable the a/c from coming on automatically every time you turn the fan on? I did a search, but could find anything on the topic. I know on my old RSX, it used to have the same feature, but I disabled it (by following some forum directions).
Thanks!
B
Thanks!
B
I don't think that you can turn off the auto a/c. I know that you can turn off just the a/c and the auto but I am not sure what happens when the car says no a/c. When it says no a/c or something like that above the temp is it in auto without a/c? Good question.
it's me, Alan Rickman.
I know it's your car... but why?
If you're wanting to do it for horsepower or mileage reasons its completely not worth it at all
You can hit the a/c button, which will turn it on or off, also disabling auto climate control. The next time you hit auto, it's back on as needed, and i'm 99% sure it's on when you turn on the defroster.. there's not just a simple switch to turn off - it's controlled by programming in the vehicle. You could always pull out the compressor though, that would turn it off for good.
Registered but harmless
Received 1,106 Likes
The A/C will then never turn on, even after restarts, unless you push "Auto," A/C (to turn it on) or the front defroster.
I never bother with the fan speeds-- if it's too warm, I lower the windows or push "Auto" to let the A/C adjust the temp.
Registered Member
Thanks!
B
Thanks!
B
In fact most of the time, this is exactly how I have my HVAC set. In the summer time when I do use my A/C, I just press the AUTO button and set my interior temperature to the desired setting. Otherwise, I use the manual mode with the A/C off and just direct the vents and fan speed accordingly.
As for the defroster, most of the time I do not let the defroster run with the A/C one. I only do this on warm and humid days. When I want to use the defroster without the A/C, I just say, "climate control floor and defrost" and I get air directed to the floor and windshield without A/C.
Originally Posted by Will Y.
My TL is set for 68*F, A/C off-- I just push the "Auto" button, then the "A/C" button (which shuts off the A/C).
If you press auto on the climate control and then press the a/c button, the compressor will not run. The system still does every other function automatic. ie fan speed, air flow, ect. If you just use the temp settings the car will still automatically maintain that temp(unless it is too hot for it to do so with out the compressor.
Registered Member
As I wrote in post #6 and will add, the only time my A/C comes on is when I direct it to do so. All other times, it is off. My car and my HVAC does not default to the AUTO setting nor does it default to operating the A/C. To do so requires my direction which is exactly what I want.
I don't know what those guys are thinkin' (or drinkin').
I personally never use the "auto" feature unless it's real humid and cool at the same time. Then it's great for selecting the proper defrost by cycling the compressor when needed.
Registered Member
Originally Posted by S PAW 1
Exactly!
Exactly!
What year is your car? Maybe they changed it for '08?
That's weird. Mine is set to come on every time I turn the vent on. So I have to turn it off each time (the A/C). Then, if I turn the HVAC off and then on again, the A/C comes on again.
When you start up the car the next time, the fan may go on if it's warm enough in the cabin, but the A/C compressor will NOT activate.
Thanks Will. It's weird because when you hit the vent buttons, the display doesn't read "A/C on", but it also doesn't read "A/C off". It makes me think that the A/C is on when there is no indication of either in the display, because I can feel the compressor kicking in I think. Anyway, thanks for the tip. I tried it last night, but I think I screwed it up because I was going off of memory. I'll try it later tonight again.
THE PLANE TAKES OFF!!!!!
I rarely use anyting other than auto
99% of the time it's on auto 73 degrees, because i dont have to fuck with the temperature anymore.
Registered Member
Originally Posted by fish008
Your car didn't say "a/c off" when you pushed the a/c button? That is weird. When you push the a/c button the word auto goes away and is replaced by "a/c off."
MrHeeltoe
20
02-23-2023 01:54 PM
MrHeeltoe
09-29-2015 10:43 PM
MrHeeltoe
09-28-2015 05:43 PM
