Disable "Key in ignition" beep
I searched and could not find. How can you stop the annoying beeping sound while the key is in the ignition and the door is open? There are times when I'd like to have the car doors open to listen to music but that annoying beeping ruins it.
Does this bother anyone else?
Slacker
i thought if you have the key all the way forward just before ignition (ON (II) ?) position it would go off after a few beeps, ive done this i thought while detailing the interior, ill have to check to make sure i just didnt have the radio louder than the beep!
04 TL 6MT NAVI ABP/Q
If you really want to disable it, ot the headlights on chime, try this thread,
https://acurazine.com/forums/showthr...22#post1004222
Originally Posted by mxtt
If you find a way to disable the beep, you will be bitching about how you locked the door with your key inside. Just live with it.
![Scared](https://acurazine.com/forums/images/smilies/scared.gif)
The beeps will go off only if you close the driver side door.
soupi
14
11-15-2015 11:15 AM
