Different ECU in 3 Gen Type S
Old Nov 8, 2017 | 06:56 AM
Efthimios's Avatar
Do early production models made in 06 have a different ECU and higher compression?
Old Nov 8, 2017 | 07:06 AM
ALL TL's have the same compression. 11:1
the 2006 TL ECU actually got restricted in 1st gear to limit traction loss.
the one you are thinking of is the 2004 Acura TL 6MT Aspec. this car had an ECU tuned with aggressive timing... but again, by 2006 Acura wised up and limited that.
Old Nov 8, 2017 | 07:49 AM
Ron A's Avatar
Administrator
Welcome to the forums.
Since this is a technical issue which will require replies, and not a "New Member Introduction", I moved this thread to the model specific forum.
Old Nov 12, 2017 | 03:24 PM
Waffeey's Avatar
Does the ECU limit the engine in 1st even with VSA off? I have a 06' base 5AT and i've noticed during hard launches with the VSA off the car doesn't like to spin tire past 2500rpm it almost feels like the traction control is kicking in. Always thought this was just because of this car having more grip then i am used to coming from a 140hp integra that could spin through first
Old Nov 13, 2017 | 04:35 PM
truonghthe's Avatar
I think we all know why your tires isn't spin
Old Nov 14, 2017 | 12:01 AM
Waffeey's Avatar
Understand that the torque converter isnt going to spin the tires as much as compared to popping the clutch in a 6MT but the reason why i ask is because when i launch from 2nd gear my tires spin so why wouldnt 1st spin all the way through? Would make sense if the ecu was reducing timing to make 1st gear slower which is my question. Thanks.
Old Nov 14, 2017 | 01:49 AM
thisaznboi88's Avatar
06 TL have a hybrid between a 04 and an 07 ecu for the MT. It uses 5 pin connector for the Mt so it can use hondata, but still needs you to wire in the can us to obd2 wires. As for the auto ecu I believe it is similar to the 04 ecu.
If if you have a my get hondata and spin all you want. Unlock all limitations and speed restrictions
Old Nov 14, 2017 | 05:58 AM
^I finally got Flashpro!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! i'm so excited!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! !!!!!!!!!!!!!!!!
will install next week
Old Nov 14, 2017 | 09:52 AM
tranny
Darksyne
23
Nov 2, 2017 09:52 PM
hmongcuzzo
Sep 20, 2017 12:21 AM
rets
Jan 1, 2013 09:50 PM
