Day time light??
Old Mar 10, 2010 | 08:02 AM
Bayam0n's Avatar
Veni, vidi, vici
Day time light??
I would search for this, but I have no idea what the name of it is. on the 04-06 TL's there are three lights in front headlights. The Turn signals, the high beams/lowbeams, and then the lights closest to the grill, which are ???? are they fog lights? daytime running lights? I'm asking because I hate that yellow pi$$ color and I want to swap them out (I'm getting the headlights cleared soon, getting the switchback as well, and I hate yellow) .
Does anyone know what bulb fits in there??? any hyperlinks would be great. and if you have a link to V-LEDS.com then that's even better because that's where I'm going to get the bulb from.
Thanks!
Old Mar 10, 2010 | 08:46 AM
Jesstzn's Avatar
If I'm not mistaken in the US car they are fog lights.
Old Mar 10, 2010 | 08:57 AM
CLtotheTL32's Avatar
Those are the fog lights. You cannot put LEDs where a regular halogen bulb goes.
You'll need 9006 bulbs if you want to replace those. I just got some cheap ass ones off of eBay. Similar to these:
http://cgi.ebay.com/ebaymotors/9006-...ht_2379wt_1173
Here's what they look like on my car:
Sorry for the shitty iPhone picture. I'll take a picture with my D60 this afternoon if you want.
Old Mar 10, 2010 | 09:33 AM
Bayam0n's Avatar
Veni, vidi, vici
so 9006 HID would fit right??
Old Mar 10, 2010 | 11:00 AM
swoosh's Avatar
takin care of Business in
completely wrong INFO in this thread:
you can put anything that is 9006 out there !!!
1> 9006 LEDS
2> 9006 Halogen Bulbs
3> 9006 HID (you will need a HID kit for this)
check this link out for more info:
http://autolumination.com/headlights.htm
Old Mar 10, 2010 | 11:04 AM
Jared234's Avatar
Those are foglights on the 04-06?
They are DRL on 07-08 weird
Swoosh is right, and the stock HID light is 4300k if you want them to match
Old Mar 10, 2010 | 11:10 AM
Dat Boi Ralph's Avatar
2004 SSM FTMFW !!!!
^ he is correct, I use mine as DRL 9006 3k hid
Old Mar 10, 2010 | 11:38 AM
swoosh's Avatar
yes on 04-06 US models they are FOGS and on 07-08 models they are DRL's. But regardless there is a relay available to switch them around as you want them !!!
stock bulbs are 4300K (white with a hint of blue) !!! Lemme take some pix of my car with LED fogs and put em up !!!
Bayam0n's Avatar
Veni, vidi, vici
Thanks alot, I really hate that yellow color.
Old Mar 10, 2010 | 02:11 PM
o4Komodo's Avatar
Rev High; Drive Happy
In Canada o4-o8 are all DRLs.
Old Mar 10, 2010 | 02:20 PM
swoosh's Avatar
^^^ LOL yeah thats why i said 04-06 US models
lol @ your avatar....
Old Mar 10, 2010 | 02:49 PM
o4Komodo's Avatar
hahah, yeah... I was just trying to make it a bit confusing =]
My avatar... hahah, I should make a new one. My DRLs are now ale to turn on as foglights. =]
Old Mar 10, 2010 | 04:31 PM
swoosh's Avatar
^^^ sweet...did u happen to mess with the relay? how bad was it ?
Old Mar 10, 2010 | 04:47 PM
dwb993's Avatar
I installed the DRL module on my 06 fogs. Works very well. Got it from Autobarn---search for "Daytime Running Lights". Chuck the wiretaps they send with the kit and either solder or buy good taps.
You should not use HIDs as DRLs---the relay only supplies 75% power to the DRLs (thus making them DRLs) which may mess with the ballasts. I have no experience with this, but read it in one of the numerous threads on this topic (Search is your friend).
Swoosh, thanks for clearing up the inaccurate info (CL, you should know better!)
I currently run 9006 Nokya Yellows in my fogs, with 5000K HID Accord fogs in the lower grille (also 9006). Obviously, you want something cleaner. The Nokya Arctic Whites were the closest I found to matching the OEM headlights as a "PnP" solution. However, you should note that these bulbs are Stage 2 55W bulbs and you run the risk of frying wires if you run them. You can always install a relay with heavier gauge wiring, but at that point, you might as well ditch the whole DRL thing and install HIDs.
JnC recommends SilverStar Ultras, but I found them to be unsatisfactory and they looked a lot like the pics posted above by CLtotheTL.
Remember that these housings were not designed for HIDs and will throw out a lot of glare.
One final note--you may see these bulbs advertised as "H11". They are one and the same and can be used interchangeably in this application.
My
Old Mar 23, 2010 | 07:39 AM
Bayam0n's Avatar
Veni, vidi, vici
Ok, thanks everyone. So I getting alot of mixed answers. How about some one direct me to a set of bulbs or HID's that are pure white and that won't give me any problems.
Old Mar 23, 2010 | 07:44 AM
Bayam0n's Avatar
Veni, vidi, vici
http://www.v-leds.com/Exterior-HID/9...72096-1-2.html
^^^ are these a good fit???
Old Mar 23, 2010 | 10:15 AM
swoosh's Avatar
9006 for 04-06 TL
9005 for 07+ TL and TL-S
Again this is for US market....dont know about Canadian market !!!
Old Mar 23, 2010 | 11:32 AM
TailoredTL-S's Avatar
That turbo though.....
Originally Posted by Bayam0n
You need the HID Kit the ballast and igniter, you cant just throw in some HID bulbs
Old Mar 23, 2010 | 11:34 AM
swoosh's Avatar
i missed out on that completely !!! i was more concerned about the bulb type
Old Mar 23, 2010 | 10:17 PM
WhteTLS's Avatar
You definitely need a ballast with that. You can get a entire set on ebay for like $50 (cheap quality) or a better one for like $150 and up..
Old Mar 23, 2010 | 10:20 PM
WhteTLS's Avatar
this is straight from your site Bayam0n...
http://www.v-leds.com/Exterior-HID/9...82945-1-2.html
Old Mar 24, 2010 | 05:56 AM
dwb993's Avatar
^^Whoa--expensive.
Try ddmtuning.com for a slim ballast kit. You can also look at HIDextra.com, since they are a vendor on AZ.
Old Mar 24, 2010 | 10:05 AM
swoosh's Avatar
i would go ddmtuning
mada51589
Jan 9, 2025 04:40 PM
SpraykwoN
ILX
Sep 23, 2015 11:44 AM
theinsvnity
Sep 10, 2015 10:22 PM
prox
5G TLX Problems & Fixes
Sep 1, 2015 02:03 AM
ptbarnett
3G RLX (2013+)
Aug 30, 2015 12:39 PM
